Try to peek in, under the top far rear of the front fender, at the base of the A-column, where it is spot welded to the top driver's side of the firewall. You may be able to see in there by opening the driver's door and looking above the hinges.
- It's my understanding these trucks tend to crack the metal there. That may be your leak.
