Need help identifying hose
Postby BRUISER » Thu Jan 11, 2007 7:25 am
I have 3 hoses coming out of firewall and one is not connected.. I need to figure out what it is for.
first pic is a shot from front bumper looking in to give you a refernece, then the next 2 pics are closer to show more detail on hoses
In the last pic yuo can see the one empty hose.. I am guessing a vaccum line but to what?? there is nothing else not connected on that side of engine that I can find..
Thanks for any help
Ken C
'92 W250 4x4 - 5 Speed
www.impaks.com ( my projects )
www.nc4x4.com ( Moderator )
www.cnc4x4.org ( VP )
BRUISER
Postby 2stroke » Thu Jan 11, 2007 8:39 am
mine is the same way. maybe that hole is a water drain?
2stroke
Postby sdstriper » Thu Jan 11, 2007 9:50 am
It's not a missing line. It is solid in there. I drilled right thru there and ran my pyro wiring in thru it.
sdstriper
Postby dpuckett » Fri Jan 12, 2007 8:28 am
not a bad idea, sdstriper. Wish I'd thought of that. I have a yellow wire going over my firewall, into the grommet I had to slice to get all my other accessory wires/ hoses through.
DP
Postby RumbleFish » Sat Jan 13, 2007 7:02 pm
you're not the only one daniel
