Fogger water-meth nozzles
Postby Begle1 » Mon May 05, 2008 2:51 pm
Has anybody ever used these critters before?
The concept is that the water hits the little wire at 100-1000 PSI in order to aid atomization. 1000 PSI max (which is good if I ever get a real pump), 450 degree max (which is kind of scary, assuming the first thing that melts off is the little wire), and made of brass. $22 a piece from McMaster Carr...
From left to right we have a 6.6GPH@100PSI, a 12.60GPH@100PSI and a 26.40GPH@100PSI.
Do I run them?
Postby mprmn08 » Mon May 05, 2008 4:18 pm
what do you mean by 450 degree max? i've never heard or seen of nozzles like that but the concept seems like a good idea as long as nothing melts.
mprmn08
Postby SChandler » Mon May 05, 2008 4:43 pm
Begle, it seems to me that 450 should be an ok temp range for the intake. Seems to me that the highest intake air temps that I've seen were in the 300-350 degree range. My .02. Plus, you'll have the (relatively) cold water/meth mix spraying on that wire, the cooling effect that the water/meth has on the air should help the little wire live too.
SChandler
Postby nooblet » Mon May 05, 2008 9:40 pm
So, you thread those into the inside of your intake? I can see how they would aid atomization though, neat little deals.
Chris
nooblet
Postby Begle1 » Tue May 06, 2008 6:10 pm
Alright guys, so how do I thread them into my intake?
Crap...
Postby mprmn08 » Wed May 07, 2008 12:52 pm
they actually look like you'll need to put in a double sided female coupler and put the nozzle on the inside of the intake and screw in your water/meth line from the outside of the female connector. just a thought. even a female.male connector would work too just need a female end on the water line.
mprmn08
Postby nooblet » Wed May 07, 2008 1:10 pm
Can you put a quarter next to one and take a picture? I'm having a hard time telling exactly how big those are :oops:
They seem really large...
Chris
nooblet
Postby Begle1 » Wed May 07, 2008 4:29 pm
Here's what I did.
I picked up three NPT male-male couplers, and tapped one side on each one. Then I filed off the points on the hex heads on the nozzles.
Then I drilled and tapped them into the head.
That's a temp sender on the back.
Next time take better advantage of the taper of NPT taps in order to better sink the nozzle holders... :?
Postby mprmn08 » Wed May 07, 2008 6:15 pm
Those look pretty sweet man. hopefully they work. make sure you keep us informed on the progress of how they work.
mprmn08
Postby nooblet » Wed May 07, 2008 9:20 pm
Looks good, that helps me with the size thing. For some reason I had it stuck in my head that they were bigger than that. I kept thinking to myself, "they can't be that big" :oops:
Do you think that will affect air flow very much?
Chris
nooblet
Postby Begle1 » Wed May 07, 2008 10:32 pm
I'm sure the benefits of the water will outweigh the loss of airflow.
I'm not planning on keeping that intake horn for very much longer anyways...
If it's too bad I could retap holes in the back and put blank covers in the front. I could use the covers to make sure the nozzles are all spraying.
Users browsing this forum: No registered users and 57 guests
