We have all read the post: I have a 1st. Gen truck should I be concerned about the KDP since it is primarily a 2nd. Gen problem? The answers vary between no, maybe, and yes. IF YOU HAVE NOT CHECKED YOUR KDP DO IT AS SOON AS FEASIBLY POSSIBLE, YOU MUST KNOW THAT EVERYTHING IS OKAY INSIDE YOUR TIMING GEAR CASE BEFORE YOU FILL YOUR TRUCK AGAIN. Okay, now I feel better. In reading these post it always seemed like there was a big deal being made over a little "pin". Well that little "pin" is 3/8" in diameter and 5/8" long and sits right above the cam gear. Even if it somehow does not break your cam in two, go out through the case, take out your oil pump and falls down in your oil pan one of his buddies the KCBs'(Killer Case Bolts) will probably finish the job. I took all of them out with my fingers when I changed my gear case. On a positive note my cam retainer bolts were tight. Here are a couple of pictures and there are more here: [url]http://s116.photobucket.com/albums/o28/DieselRam250/KDP%20Pictures/[url]
[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/KDP%20Pictures/S5009604.jpg[/img]
Here you can see one of the KCBs' peeking out from behind the cam gear where it wore the head and shoulder to the point it looked like an acorn bolt.[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/KDP%20Pictures/S5009404.jpg[/img][/img][/url]
