pump gear
pump gear
Postby turboram » Tue Jun 18, 2013 4:35 pm
Anyone have trouble with pump gears cracking? I've cracked two and just caught them in time before destruction
turboram
Re: pump gear
Postby dazedandconfused » Tue Jun 18, 2013 4:46 pm
There have been a handful that I've read on here have cracked in this past year. I'm wondering if its from over tightening the nut on it.
Re: pump gear
Postby RCCUMMINS89 » Tue Jun 18, 2013 5:03 pm
Ya............I've actually heard of it happening a lot. Not sure the cause though.
Re: pump gear
Postby Mark Nixon » Wed Jun 19, 2013 8:43 pm
IF the KDP strikes, it tends to do bad things.
Personally, if it ever came down to having an engine that the KDP was either missing, or had obviously been lost, I'd replace the gear.
I don't trust anyone else's work.
Re: pump gear
Postby ellis93 » Thu Jun 20, 2013 3:33 am
Happened to me,but it was a hairline crack and not but about 2 inches long. Was enough for me to worry about :lol:
Re: pump gear
Postby 1990CTD » Thu Jun 20, 2013 7:01 pm
If your talking about the gear in the timing case that connects to the pump, yes, when I replaced the injection pump on mine the gear had a hairline crack in it. Its not cheap either if I remember correctly be cause I replaced it.
1990CTD
Re: pump gear
Postby stoneagemaxx » Sat Aug 24, 2013 12:10 am
Factory one on my 92 split when I was doing 70 pulling a trailer bent the pump drive shaft but nothing else I showed it to a friends dads buddy that did prototyping on cummins motors for year's said he had never seen it before this was in 2007
91 d250. 2wd std cab i/c convert 3.07 rears autometer guages htt stage 3 turbo 47rh convert 2 manualy controled od an lockup turns on fuel screw .5 on smoke screw and fuel pin rotated 3800gsk timing jumped 1 tooth retarded on pump settings for now resealed ip to come in spring he351ve and full 4 in ex hopefully injectors coolertubz for the other rig thanks Tim
stoneagemaxx
Re: pump gear
Postby brandonmgreer » Sat Aug 24, 2013 9:43 am
I have seen one cracked and a couple with teeth messed up... I'm like Mark Nixon, I don't trust anyones work, but KDP in question, I'm checking eveything out!
brandonmgreer
