Does anyone know the maximum number in degrees one can tilt an engine backwards. Without causing front shaft/bearing issues in the trans and oiling issues in the engine?
Also, can someone give me a stock tilt angle?
My mess is currently tilted back (by my doing on purpose) at 6 degrees. If I can safely run it at 8-9 degrees.... I can them clock the case downward and be ok on my front shaft again as well as shim the rear downward 3 degrees and have all of my driveline angles be ok.
