Engie/trans/case tilt angles
Postby RCCUMMINS89 » Sat Apr 26, 2014 9:03 am
Does anyone know the maximum number in degrees one can tilt an engine backwards. Without causing front shaft/bearing issues in the trans and oiling issues in the engine?
Also, can someone give me a stock tilt angle?
My mess is currently tilted back (by my doing on purpose) at 6 degrees. If I can safely run it at 8-9 degrees.... I can them clock the case downward and be ok on my front shaft again as well as shim the rear downward 3 degrees and have all of my driveline angles be ok.
Re: Engie/trans/case tilt angles
Postby grinnergetter » Tue Apr 29, 2014 5:41 pm
93 ext cab was 5 degrees.
grinnergetter
Postby RCCUMMINS89 » Tue Apr 29, 2014 7:23 pm
So my 6 isn't too bad.... I wonder if I can run 8. Anyone?
Postby DMan1198 » Wed Apr 30, 2014 10:35 pm
I think you should be able to do it since the pickup will still be in the oil
Postby ellis93 » Wed Apr 30, 2014 10:41 pm
RCCUMMINS89 wrote:So my 6 isn't too bad.... I wonder if I can run 8. Anyone?
I'll measure what I have in the 82. It's pretty extreme
Postby BobS » Thu May 01, 2014 6:12 am
Here is the guide that I always refer to. It comes directly from the manufacturer. Note the relationship between the engine front to rear tilt and the rear axle pinion tilt and the specified tolerances.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
I always try to set the angle to the positive side because the transmission rubber mounts will be guaranteed to sag and settle in.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby RCCUMMINS89 » Thu May 01, 2014 10:11 am
That is the guide that I used to realize that my angles were way too much.... my overall u joint movement is over double the maximum recommendations.
Postby DodgeFreak » Thu May 01, 2014 10:26 am
it'd be somewhat costly. But have you thought about a divorced tcase?? I'm not sure if you'd have the room though.
Postby RCCUMMINS89 » Thu May 01, 2014 11:19 am
Yes, I have actually thought of it... but that would be a last resort, and even then... I would probably live with it.
