no oil pressure
no oil pressure
Postby gobcumminstruck » Sat Aug 31, 2013 4:23 am
i was driving home last night, from work and oil gauge went to zero and light came on. i heard a noise and pull over to side off road. and the noise came from rt side of truck toke pipe of turbo and it was it. i limp it about 5 miles back to work.i put an mechanical gauge on oil filter houseing and find i had no oil pressure. its an early 1991 w250 non intercooled engine. and the truck has close to 600,000 miles on it i dont know for sure the excet miles, cause the odometer has work since i bought the truck and dont know how long it hasn't work. what could be my problem?
Last edited by gobcumminstruck on Sat Aug 31, 2013 4:27 am, edited 1 time in total.
gobcumminstruck
Re: no oil pressure
Postby PToombs » Sat Aug 31, 2013 4:26 am
If the turbo failed it may have dumped all the oil out of the engine. Either thru the tailpipe or it went thru and burned it.
Re: no oil pressure
Postby gobcumminstruck » Sat Aug 31, 2013 4:33 am
i check the oil stick and it has the right amount. i check it wend i got to work and let it sit and check againt it had more in it, meaning it was pass the full mark and it was black to, no fun color oil,and coolant full to. no coolant loss and coolant not different color.
gobcumminstruck
Re: no oil pressure
Postby Remps » Sat Aug 31, 2013 10:10 am
I am suprised you made it 5 miles with no oil pressure. Are you sure you used a working gauge? You could pull a valve cover and fire it up and see if the oil flies or not.
Re: no oil pressure
Postby gobcumminstruck » Sat Aug 31, 2013 10:55 am
i m to. the gauge works its an set i very carefull with thst i buoght to chek engine and or transmission pressures with. its an mac brad. and if say the oil by pass the oil filter and turbo then y the truck gague not workin cause it was workin before this
gobcumminstruck
Re: no oil pressure
Postby Remps » Sat Aug 31, 2013 11:02 am
Well, I am stumped lol. I know my oil pressure gauge quit working on my D250 a few years ago. Shut it off and pulled over and pulled a valve cover and started it, and oil went flying everywhere, so it was just my gauge.
Re: no oil pressure
Postby ellis93 » Sat Aug 31, 2013 1:23 pm
I have an engine that did that and the kdp took out the oil pump idler. I think the first place to go is to that front cover and remove it.....
Re: no oil pressure
Postby gobcumminstruck » Sat Aug 31, 2013 3:30 pm
I know the gague senor works cause I replace it an year ago so I guess it works stall I guess. And wend I got the truck 2 years ago I made an plate to cover pin and red lock tight the bolt. I plan to take cover off to check it and the oil pump. I just see what ya's thoughs on it and see if this happen to someone to. I also find oil presuer regulater and check it.
gobcumminstruck
Re: no oil pressure
Postby gobcumminstruck » Tue Sep 03, 2013 9:02 am
does anyone know how to get the oil pressure regulator out? i got spring out put cant get the pison out or whatever u call the thingy under the spring. i stall goin take ft cover off as soon i can get it from work to home.
and check oil pump.
gobcumminstruck
Re: no oil pressure
Postby ellis93 » Thu Sep 05, 2013 3:56 pm
Well :scratch: what was the problem?
Re: no oil pressure
Postby gobcumminstruck » Thu Sep 05, 2013 6:17 pm
i dont know havent got an chane besides i been thinking of junking it case i need an vechinl to drove t work and dont hav the money to fix i think it be oil pump and need an new oil cooler cover cause the plunger for oil pressuer regaltoer is suck in it an cant get it out. and i need an turbo thats y i ask about them
gobcumminstruck
Re: no oil pressure
Postby ellis93 » Thu Sep 05, 2013 6:31 pm
Junk it? Damn that sucks :yuck:
I bought a used oil pump off of Ebay for 35$,the rebuild for the turbo should be less than 150$ (if you need a turbin shaft I can hook you up) as far as the bypass if its stuck in....who cares,cap that baby back off and forget about it (it's stuck closed right? )
Re: no oil pressure
Postby gobcumminstruck » Thu Sep 05, 2013 6:49 pm
ok. i not sure were it stuck at i just dont hav oil pressuer anywere in engine i dont hav much money to fix right now so it either sit or junk so i hav/get sometging to drve. ya it does suck.
gobcumminstruck
Re: no oil pressure
Postby gobcumminstruck » Thu Sep 12, 2013 9:17 am
well its for sure it needs an turbo and oil pressure regulator. and maybe and cooler cover cause the reglator suck in it and i need money and somwthing to drive and onlyu way i can is sell truck as whole or juck it. thanks for the help
gobcumminstruck
Re: no oil pressure
Postby davidandrew » Fri Sep 27, 2013 5:05 am
Change turbo or repair turbo. By doing so your problem may be fixed
davidandrew
