Tacoclaw wrote:I had a Chrysler Conquest, it was an awesome little car. Unfortunately, they used a throttle body injection system that had a weird operating setup and it sucked wondering whether it was going to run right that day.
When it did run right though it was an awesome car. There wasn't an intersection around I didn't leave sideways. That had was setup so that once you were sideways you didn't even have to mess with the steering wheel. It was easily controlled with just the throttle. I loved that car.
CumminsPower59 wrote:I enjoy messing with the VE...but one thing I can't figure out on mine is that right now it is about halfway between stock and max on the fuel screw...if I turn it in more it does what is should except when side stepping between part and full throttle it will damn near die and kick right back up to idle. The further it is in, the worse it gets with the RPM drop, at just about max, it'll die when the RPM's come down from part-full throttle. I can't figure it out, so it's been set mid range for now
RCCUMMINS89 wrote:CumminsPower59 wrote:I enjoy messing with the VE...but one thing I can't figure out on mine is that right now it is about halfway between stock and max on the fuel screw...if I turn it in more it does what is should except when side stepping between part and full throttle it will damn near die and kick right back up to idle. The further it is in, the worse it gets with the RPM drop, at just about max, it'll die when the RPM's come down from part-full throttle. I can't figure it out, so it's been set mid range for now
Mine used to do that when it was near runaway..... it doesn't do it anymore though??? Fresh return springs maybe?
CumminsPower59 wrote:RCCUMMINS89 wrote:CumminsPower59 wrote:I enjoy messing with the VE...but one thing I can't figure out on mine is that right now it is about halfway between stock and max on the fuel screw...if I turn it in more it does what is should except when side stepping between part and full throttle it will damn near die and kick right back up to idle. The further it is in, the worse it gets with the RPM drop, at just about max, it'll die when the RPM's come down from part-full throttle. I can't figure it out, so it's been set mid range for now
I got some that I could throw on. I'm thinking it may have something to do with the governor assembly sticking or not catching the RPM's as they come down...or something of the sort, that's the only thing I can think of....
dazedandconfused wrote:Well looks like I need a pcm for the Ford. I swapped in my 5speed 95 pcm and the pos started.
