Postby cmann250 » Mon Jun 23, 2014 3:29 pm
oldestof11 wrote:What was your fuel level at?
I can't do much more than I do now on stock 235's. If I try to boost, I spin. If I boost a little it spins a little. That and my OD is having issues.
FWIW, my old w250 manual ran those first 2 times you have listed. Your auto is doing good.
I had more than 3/4 of a tank. I also run bald Firestone Steeltex tires in a 235 width out back. I had my foot on the throttle just enough to take the slack out of the TV cable, so I was still under 1000 rpms and thus making zero or near zero boost.
RCCUMMINS89 wrote:What lift pump are you using? I never sucked anything dry with the factory lift pump.... with 3/8" supply and 5/16 return, and that was with zero psi of fuel pressure and dynoing over 400.
I have a Cummins low pressure piston pump and factory fuel lines, which I believe to be 5/16" both ways. I've never had this issue before on the street or dyno. Kind of puzzles me.
Postby RumbleFish » Mon Jun 23, 2014 4:06 pm
Tacoclaw wrote:I'm on my waaaaayyyyy, I'm on myyyy waaaayyyyyyy, hoooome sweeeet hooooome.
How long is that trailer levi? Your rc sure fills it up.
Postby PToombs » Mon Jun 23, 2014 4:22 pm
I was wondering size that trailer is also. Kinda small to be to do real work with. I heard that's what his gf says too. :lol:
Postby oldestof11 » Mon Jun 23, 2014 5:44 pm
I wouldn't say your lift pump is doing that. What's your AFC line like?
Postby cmann250 » Mon Jun 23, 2014 6:19 pm
oldestof11 wrote:What's your AFC line like?
It's a 1/2" poly line with a ball valve in it that serves as my valet switch. Granted I don't have a tach and I had a Duramax at full tilt in my ear, but I think the engine severely hiccupped or died and then came back a little farther down the track. Can the AFC have that big of an impact?
Postby Kasper Cummins » Mon Jun 23, 2014 7:42 pm
Tacoclaw wrote:I'm on my waaaaayyyyy, I'm on myyyy waaaayyyyyyy, hoooome sweeeet hooooome. :)
Pic is a little late, I've had it home all weekend and already swapped core supports and have fenders hanging on it now. Besides the DP dumping right under the x-fer case shifter hole, it's a pretty nice ride. :grin:
The GM rims look nice, now just need some dodge center caps.
92 W250 club cab
Kasper Cummins
Postby Tacoclaw » Mon Jun 23, 2014 8:04 pm
No idea how long it is but, you're right, it's not very. We towed a '56 power wagon on it Sunday, so it's technical long enough for a longbed pickup.
It's nice for hauling skid steers and mini-hoes around, the climb up the ramps isn't as bad as the normal gooseneck we've got with the moveable dovetail.
Postby DMan1198 » Mon Jun 23, 2014 8:54 pm
Haha hoes.
On another note that s480 is wicked. I didn't have a chance to make a video because the semi was going as fast as I was
Postby Tacoclaw » Tue Jun 24, 2014 12:54 pm
Here's my project for the weekend. It usually runs but didn't have spark, and it hasn't stopped in a while so I'll be digging into the brakes. Little cousin wants to get this one driveable, then we've got another one with a rough body.
I'm thinking since none of you bastards want my truck frame we'll just throw the other body on it with the RC drivetrain. He wants to put a cummins in it eventually, so it'll pretty much be ready for whatever 1stgen drivetrain we track down to bolt in.
Postby matthewh » Tue Jun 24, 2014 1:09 pm
I officially hate you Levi :lol: . I love old WDX power wagons, always wanted one, just don't have the deep pockets to buy a decent one, settled for an M37 instead.
Nice looking truck, with a winch nonetheless
matthewh
Postby Tacoclaw » Tue Jun 24, 2014 1:19 pm
That's funny, I personally prefer the M-37's.
They're all technically my cousin's trucks, my dad got out of the military truck game a few years too early for me to benefit, this was one of his old trucks he sold to my uncle.
Honestly, when the body on my old dodge finally evaporates I may look into some older iron to reskin it. It's not like panels from the 50's are any harder to find than 1stgen panels. :lol:
Postby dazedandconfused » Tue Jun 24, 2014 4:59 pm
Okay can someone tell me where the length difference is made up on a 8' bed when compared to a 6'? I'm trying to figure out if its longer in front and back or just the front. Clear as mud?
Postby AHineman » Tue Jun 24, 2014 5:15 pm
Tacoclaw wrote:Little cousin wants to get this one driveable
You must mean younger cause I know you're the littlest Thompson. :P
Postby DMan1198 » Tue Jun 24, 2014 5:20 pm
I'm pretty sure they just add length to in front of the wheels for long beds.
Postby RCCUMMINS89 » Tue Jun 24, 2014 5:38 pm
So I put another head gasket on my truck.........didn't re surface anything or nothing... just flopped another one on there. Truck runs a little stronger now to say the least.
