steel tank weight?
steel tank weight?
Postby IowaCummins » Tue Jun 23, 2009 6:54 pm
hey guys i have a question about a steel tank. ok i work at a golf course and we have this big irragation tank that is not in use any more and my boss said if i can get it out of there i can have it. so the challenge is on. this tank is 28' long about 10' diameter and its half inch thick steel. my question is how much you guys think this weighs? i was thinking of rolling it on to a gooseneck trailer. but i am kind of hesitant of rollignit on there and something bad happening. if some one knows how much a 1 foot square of 1/2" weighs i could find it out by measureing around and doing the math. any thoughts guys? i was going to use my plasma cutter but i would have to get atleast 125 foot of power cord or a good generator.
IowaCummins
Postby Begle1 » Tue Jun 23, 2009 7:46 pm
http://www.turnersteelcoinc.com/html/plates.html
Looks like it's around 21 pounds per square foot.
My calculations say that the surface area of a 10' diameter, 28' long tube is around 1,040 square feet; that means that the tank should weigh at least 20,000 pounds.
Quite a load.
Postby KTA » Wed Jun 24, 2009 12:14 am
You sure it is 1/2" thick? That is incredibly thick for a water tank. 3/8 would seem like over kill.
Postby IowaCummins » Wed Jun 24, 2009 7:20 am
yea it was high pressure tank. so i guess over kill? lol
IowaCummins
Postby Begle1 » Wed Jun 24, 2009 12:41 pm
What the heck do you do with that much high pressure water?
Postby IowaCummins » Wed Jun 24, 2009 12:50 pm
spray 18 holes of golf course! lol and the fairways tees rough and greens. oh and the stupid flowers.
IowaCummins
Postby Begle1 » Wed Jun 24, 2009 5:30 pm
How much pressure are we talking?
Postby PToombs » Wed Jun 24, 2009 5:55 pm
Forget it Begle. It's too big to use on your W/M system. :lol:
Postby IowaCummins » Wed Jun 24, 2009 6:02 pm
well i dont really know. i will ask tomoro tho. all i know is its the old system where they didnt have the pumps that could keep up to the pressure drop from spraying. this tank was probably put in place it the 60s or maybe the 70s possibly older than that. some of the supply lines that i have to replace are up to 9' deep cause they didnt know at the time about the frost line adn stuff like that. so it really sucks when you see a buble in a fairway on the old side. it used to be a 9 hole course then was turned into a 18 hole. its always fun replacing that stuff.
IowaCummins
Postby Farmboy » Thu Jun 25, 2009 7:45 am
I just drew it up in solidworks, its a 3d CAD program... it should weigh 20906.951 pounds. plus or minus a few thousandths of a pound :lol:
Farmboy
Postby SOOT4BRAINS » Thu Jun 25, 2009 8:23 pm
Well if its steel, don't forget to subtract for the amount of metal lost from rust :lol: :lol:
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby Begle1 » Thu Jun 25, 2009 9:08 pm
Wouldn't FeO3 weigh a considerable amount more than regular old Fe? Since it has those three extra oxygen atoms and all?
Postby IowaCummins » Fri Jun 26, 2009 11:40 pm
begle i was thinking the same as you. plus with all the sedament in the bottom of the tank from years of use then all teh years of sitting. i forgot to ask but hopefully i will monday. so another question. do you guys think my truck can haul it? it only going to be a max of 10 miles and through the city. a buddy has a dual tandem axle goose neck 30 footer. i have to find out what the max weight of the trailer is but you think my truck can do it? good holding power tranny auto. then i just did the brakes all around with the 1 ton shoes and big wheel cylinders. im pretty sure the trailer has brakes on both axles but defffinately one. is this a good idea or should i cut her up onthe spot?
IowaCummins
Postby soggy » Fri Jun 26, 2009 11:53 pm
how are you getting it on the trailer? I think it would be pretty sketchy, hauling thru a city.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby Richie O » Sat Jun 27, 2009 6:45 am
soggy wrote:how are you getting it on the trailer? I think it would be pretty sketchy, hauling thru a city.
Naw. My old man just brought his boat down to get a new canvas top put on. When he got there he had everybodys phone and cable wires ripped off and wrapped around the radar. :D He was just a lil over height.
