by CumminsPower59 » Tue Oct 02, 2012 4:47 pm
How much of lift is on it? Sometimes, with taller lifts, people throw in degree shims between the spring pack and the spring perch on the axle in an effort to help driveline angles, which will slightly affect the steering geometry. Lifts on solid axle trucks like ours are very straightforward and not much needs to be modified or messed with after...
