by bmoeller » Sun Sep 30, 2012 8:34 am
Pull the ratio box out, and see if it turns freely. Also check to see if the pins aren't smooth. If you have a different VSS laying around, you could check to see if it is working properly. Hopefully it isn't the speedo head with some bad teeth on the gears.
NEW- '82 CREW cab dually. Cummins, NV5600, 205, D60/D80.
Work in progress......
SOLD- '99 3500, SO CTD, 5spd
