installing goosneck hitch on my truck
Postby Power Ram Man » Sun Dec 19, 2010 5:07 pm
I bought a atwood goosneck hide away hitch and. Was wondering were u are supposed to place it should it go in front of the axle or right in front of it
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Re: installing goosneck hitch on my truck
Postby PToombs » Sun Dec 19, 2010 6:18 pm
I always mount hitches (ball or 5th wheel) 1 inch in front of the axle. Some swear by right above it. Get some opinions and make your own choice. ;)
Postby dazedandconfused » Sun Dec 19, 2010 6:22 pm
Mine is just a little in front of the axle.
Postby Richie O » Sun Dec 19, 2010 7:02 pm
PToombs wrote:I always mount hitches (ball or 5th wheel) 1 inch in front of the axle. Some swear by right above it. Get some opinions and make your own choice. ;)
Thats my take as well. The whole point is to keep, or add, weight to the front axle, not take away like bumper tow does.
Postby ellis93 » Sun Dec 19, 2010 7:54 pm
Mine is 1" in front of the axle and it does add weight to the front axle if installed that way. My truck has a wondering problem, I'm always having to correct it, and it goes away whenever the truck is hooked to a trailor.
Postby realest » Tue Jan 18, 2011 5:39 am
i have been casually browsing for a hide a way gooseneck hitch. it is my understanding they don't make a kit for the first gens anymore. which kit can a guy make work for the truck? the second gen trucks?
1991 W350 Reg.Cab Dually
realest
Postby dazedandconfused » Tue Jan 18, 2011 9:22 am
B&W had one still listed a few weeks ago.
Postby RumbleFish » Tue Jan 18, 2011 1:56 pm
iirc the b&w on is 1300r
Postby 1STGENFARMBOY » Tue Jan 18, 2011 2:32 pm
I used a piece of 2 in x 6 in plate and welded the nut on the bottom so when i don't want the ball sticking up i use a pipe
wrench and take it out, yes it's a little trouble but it's alot cheaper than the others.
