Not sure what I'm doing with it, though.
If I were keeping the DAMNCHARGER.....but that's just insane thinking there.
ahale2772 wrote:thanks for the replies guys, I would go 14 bolt if i could find one with 3.54 gears, im sure I could buy those grears aftermarket but i dont really want to get into ripping the carrier out..but then again with the ability to buy a 14bolt for so cheep maybe I should...
dazedandconfused wrote:I'm personally not a fan of the 14 bolt. We have killed 8 of them like they were nothing. 2 in a stock big block 97 GMC, 1 in a 95 Chevy 3500, 3 in my 81 crew can chevy with an 89 Cummins 727 combo & 2 in a 94 Chevy 3500 6.5. They do not like the abuse we have put then threw.
Fred_M1010 wrote:dazedandconfused wrote:I'm personally not a fan of the 14 bolt. We have killed 8 of them like they were nothing. 2 in a stock big block 97 GMC, 1 in a 95 Chevy 3500, 3 in my 81 crew can chevy with an 89 Cummins 727 combo & 2 in a 94 Chevy 3500 6.5. They do not like the abuse we have put then threw.
Huh, I thought they where at least as strong as the dana 70.
What part of it do you usually break?
Is it the ring and pinion or the axle shafts or something else?
Mark Nixon wrote:IIRC there are 2 distinct versions of the Corporate 14 bolt, both have different ring gear diameters.
One is under some older Medium Duty trucks, as well as certain '70s and '80s 1 tons and has (IIRC) an 11.5" ring gear.
The other, purportedly more common, version is significantly smaller in ring gear diameter.
The one I had was definitely not the wimp of the pair, so I was told.
Always ate the pinion and ring gear. Pinion support bearing would fail and munch the pinion gear and ring gear.
