Help! W250 front suspension rebuild!
Re: Help! W250 front suspension rebuild!
Postby BILTIT » Mon Oct 08, 2012 8:27 am
Hard to say really, i have nothing but worn out stock springs to compare too. They are much better than the worn stockers though.
Derek B.
BILTIT
Postby GoldenRule » Mon Oct 08, 2012 12:16 pm
Right on, that's exactly where I'm at as well.
GoldenRule
Postby dodgeman1990.5 » Sun Oct 21, 2012 1:46 pm
I had a great experiece dealing with this company http://www.generalspringkc.com/ when i called down there i actuly talked to sombody that was worked in the shop not just a call taker(the guy i spoke with actuly gad a 1st gen). i was only looking to go a little bit higher than stock so they re-arched the springs up 2 in for me. total price with labor and shipping for two springs was $364.00
dodgeman1990.5
Postby m880cummins » Fri Nov 02, 2012 5:46 pm
I'm getting Alcans for my current project because it will be lifted.
For stock height, if you don't wan't to spend $$$$$ run late 1960s Dodge 3/4t springs. one eye has a double leaf wrap and they ride much nicer than any stock cummins spring. If you can find a good used pair, install poly bushings and run them! Not sure if new aftermarket ones are any good.
Here's the 60's springs on my last truck:
viewtopic.php?f=2&t=12926
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby little doug » Sat Nov 03, 2012 12:16 pm
m880cummins wrote:I'm getting Alcans for my current project because it will be lifted.
Charlie
I don't think useing Sweptline era front springs would work on a 92. As far as I can tell , Dodge went to a bigger front spring bolt for the 91 1/2 -93 trucks.
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
