2nd gen frame 1st gen body
Postby redneckroot » Fri Sep 02, 2011 5:18 pm
I have an extended cab 1st gen sitting here. Currently its a 2wd but will be slowly getting put together as a 4x4 puller. That being said I'd like to run a 2nd gen front suspension however the rules will not let me put my own frame mounts on to do so. But they will allow me to run a 2nd gen frame. So the question is has anyone done it? Does anyone have measurements axle to axle? I know mounting the body will take some fab work but I'm not worried about that just yet.
Since someone will probably ask the reason I want to run the 2nd gen suspension is to help avoid common problems with front leaf springs and pulling. Thanks.
redneckroot
Re: 2nd gen frame 1st gen body
Postby dazedandconfused » Fri Sep 02, 2011 5:23 pm
There use to be one that was done like that, it pulled at schied years ago. There is a big gap between the cab and bed he ran stacks up threw.
Postby redneckroot » Tue Sep 06, 2011 1:16 pm
Looking for some more info. Anyone have some insite? Anyone else pull with full pull productions or NADM?
redneckroot
