no power steering or breaks?
Postby Hansen01 » Thu Sep 15, 2011 6:10 pm
so i went to go pull a buddy out of a corn field today and out of no where i loose all power steering, so i think maybe theres air in the lines or something, so i got him out and started heading home and got to the first stop sign and have nooooo breaks just a super hard petal, what in the world is going on here? :? maybe a sheered key inside the cover?
Under construction...
Hansen01
Re: no power steering or breaks?
Postby oldestof11 » Thu Sep 15, 2011 6:30 pm
Vacuum and PS are on the same gear. You are on the right track there. :mad:
Postby Hansen01 » Thu Sep 15, 2011 7:04 pm
i didnt here anything when it happend so i wouldnt think that the gear isself is bad or a snapped shaft, anything else it could be? ive never been into a front cover
Hansen01
Postby Hansen01 » Fri Sep 16, 2011 2:04 pm
well il hopefully be into the front cover tomorrow, will update what happened when i get there
Hansen01
Postby dazedandconfused » Fri Sep 16, 2011 5:10 pm
I had the shaft between the vacume pump and ps pump sheer off on my 01 and caused the same issue.
Postby oldestof11 » Fri Sep 16, 2011 5:23 pm
But you would still have vacuum, no? IIRC, 2nd Gens had a hydroboost brake system that ran off the powersteering pump...
Postby dazedandconfused » Fri Sep 16, 2011 5:29 pm
I couldn't tell you because about 30 seconds later it made a right turn by itself and I took on 15' of ditch and landed nose down in a 20-25' hole. I meant the steering issue in my above post.
Postby ellis93 » Fri Sep 16, 2011 6:23 pm
oldestof11 wrote:But you would still have vacuum, no? IIRC, 2nd Gens had a hydroboost brake system that ran off the powersteering pump...
Not all 2nd gens, I've had a 94,95,and one junk 96 that had vacuum boosters,however I don't know about the other 2 years of P-pump trucks. I've never seen a 24 valver without hydroboost brakes
Postby Hansen01 » Fri Sep 16, 2011 6:28 pm
got the front cover off tonight and it broke the shaft clean in half, :mad: anyone know where i go from here? where to get a shaft and whatnot?
Hansen01
Postby ellis93 » Fri Sep 16, 2011 6:33 pm
Bet cha Mr Mark Nixon has one
Postby Hansen01 » Fri Sep 16, 2011 6:37 pm
im assuming that these jus break of age tho right? wouldnt mind jus getting a new shaft and seals, Marks still in my head tho lol
Hansen01
Postby ellis93 » Fri Sep 16, 2011 7:09 pm
I would doubt it would go bad over time, its not a gallon of milk :lol:
You more than likely have something it drives froze up, vacuum pump or P.S.pump
Postby Richie O » Fri Sep 16, 2011 7:34 pm
My buddy had one just break. I don't think he replaced anything but the shaft. I don't think the pump let go of anything, he just lost the vac and ps.
Postby Hansen01 » Fri Sep 16, 2011 9:19 pm
well now im in a pickle,lol one for replace everything cus somethings froze and one that says it may not be froze :? lol any way to tell???
Hansen01
Postby ellis93 » Sat Sep 17, 2011 6:15 am
There sure is.......tear it down ;). I think your headed that direction any how.
Its weird to me that a shaft would just break without a cause. There is,however,one thing I've learned about any vehicle, there is no "never" and there is no "always" to any aspect of them so "who knows" applies every time.
