Kingpins!!!!
Kingpins!!!!
Postby Haywagon » Fri Sep 23, 2011 7:16 am
Hey guys looking to replace my king pins in the 60 and loong for any and all info you guys have this is my first time ! Its a 1992 w250 4x4 with the dana 60
Thanks aaron
1992 reg cab 4x4 getrag 165K
Intake
4" pipe
366 spring
33x12x18 mud grapplers on 18x10 KMC Spy
Haywagon
Re: Kingpins!!!!
Postby manyholes » Fri Sep 23, 2011 8:32 am
search on pirate 4x4, good write on there for rebuilding the dana 60 including kingpins, get lots of cold beer, big snipe and acetylne torch. just saying itll all come in handy. i think you need 7/8" hex(allen) key/socket or a long enough piece of stock that you can bend like a allen key to get your snipe on
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: Kingpins!!!!
Postby BILTIT » Fri Sep 23, 2011 10:29 am
Derek B.
BILTIT
Re: Kingpins!!!!
Postby Tacoclaw » Fri Sep 23, 2011 11:52 am
I'd recommend only changing the springs and poly bushings in the top first, unless you know there's other problems or you just like spending money.
Those bushings fixed the tire wear/camber problem I was having. 8)
Re: Kingpins!!!!
Postby BILTIT » Fri Sep 23, 2011 12:46 pm
I have replaced two sets of kingpins in two different vehicles, both showed wear. Usually a small amount but i think its worth inspecting the kingpin atleast.
Derek B.
BILTIT
Re: Kingpins!!!!
Postby PToombs » Fri Sep 23, 2011 5:44 pm
I thought a snipe was a bird? I've heard of people going snipe hunting, then I saw one in that movie "Up". Tall colorful critter with a big pecker. (beak you perverts! :roll: )
Re: Kingpins!!!!
Postby Remps » Fri Sep 23, 2011 6:58 pm
A snipe is a torque amplifier Pete! :lol: :lol: :lol:
Re: Kingpins!!!!
Postby oldestof11 » Fri Sep 23, 2011 7:46 pm
See, Disney took some Hollywood (perve alert...) liberty in that bird. A snipe is found usually with red coloring and a dry sense of humor.
Re: Kingpins!!!!
Postby Haywagon » Sat Sep 24, 2011 5:28 pm
Thanks guys i went there and found tons of info then went to east coast gear supply for the parts and 4wd something for the tools 7/8 hex allen and 7/8 allen impact so ill let ya guys know how it goes naybe some pics too !
Intake
4" pipe
366 spring
Haywagon
Re: Kingpins!!!!
Postby PToombs » Sat Sep 24, 2011 6:49 pm
Remps, I usually call that a Pipe. ;)
Re: Kingpins!!!!
Postby ontos » Sun Sep 25, 2011 3:26 pm
Hard to believe there is no old sailor here that can explain to Pete what a snipe is.
89 5.9 non IC Freightliner motorhome Chassis 545 Allison
ontos
Re: Kingpins!!!!
Postby PToombs » Sun Sep 25, 2011 5:10 pm
Isn't it about time for you to go into hibernation? :lol:
Re: Kingpins!!!!
Postby Subliminal » Wed Sep 28, 2011 7:30 am
Just did mine not too long ago. DTR has some great writeups on the subject. Found the job relatively easy...and I had to do it in the sun in 100 degree weather:
Subliminal
Re: Kingpins!!!!
Postby Haywagon » Wed Sep 28, 2011 4:58 pm
that looks ruff ! try doing it in a single stall garage !! i haven't started just yet but got all the parts from ECGS and 4wd factory plus the tools to do it should be done in the next couple weeks due to work . Do you have any tips from your install ??
Intake
4" pipe
366 spring
Haywagon
