What Product To Use For Sealing Fuel Tank Hole?
Postby RacinDuallie » Mon Jan 30, 2012 5:57 am
I have a puncture hole in the top of my fuel tank- what product is good to use for a repair that the diesel fuel won't break down? :?: :?: :?:
RacinDuallie
Re: What Product To Use For Sealing Fuel Tank Hole?
Postby ellis93 » Mon Jan 30, 2012 6:04 am
I've used JB Weld,the quick stuff, on a few GAS tanks. I don't know how the diesel does on it.
I think some of that loctite 5min epoxy would work too
Postby RumbleFish » Mon Jan 30, 2012 7:07 am
They make a 2 part epoxy for gas tank repair. Its the dough type that you knead together. Available at any parts store. Not 100% sure its good with diesel but if it stands up to gas I would think it would be fine.
Postby PToombs » Mon Jan 30, 2012 6:01 pm
How big is the hole? If it's small use a solder gun. Heat the plastic and push it around to plug the hole, then smooth it over. Or if it's bigger, tap it to pipe thread and screw in a PVC plug with some pipe dope on it. Worked for me before.
Postby diesel freak01 » Tue Jan 31, 2012 6:23 am
NAPA sells an epoxy especially for fuel tanks. You lay a fiber layer down and spread the epoxy over it. It gets really hot. We used to used it on OTR truck alumuninum tanks so should work fine for you.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby hydroshok » Sun Sep 16, 2012 7:18 pm
JB waterweld works well.
hydroshok
Postby Ol_blue88 » Sat Dec 01, 2012 11:44 pm
i had a small hole in the bottom of my tank. i drilled it out and installed a large screw coated in epoxy. hasnt leaked in 7 years
Ol_blue88
Postby NJDodge » Sun Jan 13, 2013 6:20 pm
Screw with a piece of rubber on it. Like a bike inner tube piece. Worked for a couple years on my car now lol
NJDodge
