help! need advice 4 inches or 6.
Postby pillsbury556 » Wed Feb 22, 2012 7:01 pm
Of lift that is. I drive offroad quite a bit going with the skyjacker kit and crossover highsteer. I want to clear 35s no problem and not rub when wheeling. Will 6 inches look too big for 35s?
1993 4X4 Cummins, Getrag 360, fuel pin rotated, air filter, throttle linkage,
pillsbury556
Re: help! need advice 4 inches or 6.
Postby ahale2772 » Wed Feb 22, 2012 7:29 pm
depends on how tall the truck is now, I can clear 37's with about 3 inches of lift up front, and cut fenders, you will probably be fine with 4 inches and 35's
although a crossover is usually a bit cleaner the more the lift...
Postby oldestof11 » Wed Feb 22, 2012 8:51 pm
I have 33's on a stock height so I would think a 2-4" would suffice.
Postby pillsbury556 » Wed Feb 22, 2012 9:08 pm
Im worried that 4 inches wont make enough room for the high steer. Ugh i hate expensive decisions
pillsbury556
Postby Diesel Dawg » Thu Feb 23, 2012 2:17 am
youll probably need 6 for the cross steer.
Diesel Dawg
Postby u2slow » Fri May 11, 2012 11:15 pm
Guys have done crossover steer with 2" of lift. IMO, go with 4" lift. Less stress on the cv, and you may get by without lengthening the shaft.
I have 35's on stock (sagged) with only a tiny bit of rubbing.
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby remi » Fri Jun 15, 2012 4:24 pm
I'm running 35s with 4 inch lift and it seems fine.
i want to do that cross over steer where can you get it form
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Postby bmoeller » Sat Jun 16, 2012 3:17 pm
The 4" lift isn't enough on the 92 I had. The 35s rub on turns, with a modest droop or rise. Fine on the flat.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
