lowering advice
lowering advice
Postby jorez » Tue Mar 20, 2012 12:08 pm
I do not have the knowledge and mechanical apptitude to install Van lower control arms and make them fit...but I can get springs and hangers and do it myself..so my question is...what is the better, most cost effective way to lower a 91 D150 a few inches..it sits up too high..wife has an issue getting into it..I was thinking of some early S10 lowering springs and a rear shackle thing drop. Should drop about 2-3 inches all the way around, then sell the 22's and get some 15's.
Thanks!
jorez
Re: lowering advice
Postby dazedandconfused » Tue Mar 20, 2012 5:16 pm
Well you can cut half a coil off the spring and drop shackles in the rear. Mine has D250 lower control arms and wore out Cummins springs. It also has 2.5" drop shackles in the rear.
Re: lowering advice
Postby jorez » Mon Mar 26, 2012 6:42 am
Very nice..do you know the size tires you were running when that pic was taken?
jorez
Re: lowering advice
Postby xohcef » Sat Mar 31, 2012 11:42 pm
Nice stance, I've been ready to weld up some long shackles to drop the dually I'm getting. Maybe seeing what I can do to get some custom front coils made. :thumbs up:
xohcef
Re: lowering advice
Postby dazedandconfused » Sun Apr 01, 2012 5:11 am
jorez wrote:Very nice..do you know the size tires you were running when that pic was taken?
Its running 265/70/16's on the rear and had 215/75/15 on the front.
Re: lowering advice
Postby bigpapad150 » Wed Dec 26, 2012 12:49 pm
I have a 89 D150 I want to lower. I have found a forum that shows swapping out the LCA for van LCA and cutting a spring.
That is too much for my knowledge anyone have an easier way (not a short cut) lol.
Show or send me any pic you have of your truck in transition.
Nice stance dazed.
I'm not too far from you send me a private message. Maybe I can stop by and check out what you did.
bigpapad150
Re: lowering advice
Postby dazedandconfused » Wed Dec 26, 2012 3:19 pm
The front of mine is pretty much stock wore out 3/4 ton stuff. The Cummins pushes her down nice. Here is a link to my build thread.
viewtopic.php?f=32&t=10029&start=60
Re: lowering advice
Postby bigpapad150 » Mon Jan 21, 2013 5:18 am
dazed, still trying to get my 25 post in. I'm now randomly post boards.
bigpapad150
