Frames
Frames
Postby randyswelding » Tue Jan 01, 2013 6:46 pm
I got a 90 3/4 frame with a good back half and a 92 1ton c/c with a bad back half the welding part isn't a problem( if need be I can have X-ray dypen it) I was wondering how different are the frames since they both are 2wd frames. Thanks for any info
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Re: Frames
Postby randyswelding » Tue Jan 01, 2013 6:56 pm
I'm goin to have my dad check I found the sticky on it
randyswelding
Re: Frames
Postby bmoeller » Tue Jan 01, 2013 8:47 pm
Frame widths and height the same?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Frames
Postby PToombs » Wed Jan 02, 2013 5:50 pm
Doesn't the '90 have the small frame because it's a 3/4 ton? And the 92 is the taller frame as it's the late model and a 1 ton.
Re: Frames
Postby bmoeller » Wed Jan 02, 2013 10:08 pm
That was what I was thinking.................
bmoeller
Re: Frames
Postby cmann250 » Thu Jan 03, 2013 4:27 pm
I know my '89 3/4 ton has the small frame if that clears anything up
