Frames
Frames
Postby randyswelding » Tue Jan 01, 2013 6:46 pm
I got a 90 3/4 frame with a good back half and a 92 1ton c/c with a bad back half the welding part isn't a problem( if need be I can have X-ray dypen it) I was wondering how different are the frames since they both are 2wd frames. Thanks for any info
randyswelding
Re: Frames
Postby randyswelding » Tue Jan 01, 2013 6:56 pm
I'm goin to have my dad check I found the sticky on it
randyswelding
Re: Frames
Postby bmoeller » Tue Jan 01, 2013 8:47 pm
Frame widths and height the same?
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: Frames
Postby PToombs » Wed Jan 02, 2013 5:50 pm
Doesn't the '90 have the small frame because it's a 3/4 ton? And the 92 is the taller frame as it's the late model and a 1 ton.
Re: Frames
Postby bmoeller » Wed Jan 02, 2013 10:08 pm
That was what I was thinking.................
bmoeller
Re: Frames
Postby cmann250 » Thu Jan 03, 2013 4:27 pm
I know my '89 3/4 ton has the small frame if that clears anything up
