rocking backand forth
Postby zmm828 » Wed May 19, 2010 9:06 am
sometimes when i drive the truck will rock left to right sometimes very bad and then someimes it will slowly rock back and forth. i was think tie rods but im not for sure. what else would be causing this
90 dodge with pump work, 04 intercooler, and inake for now......
zmm828
Re: rocking backand forth
Postby gobigorgohome » Wed May 19, 2010 10:48 am
tie rods would be a good start. also check steering linkage and all steering arms/rods. there could be a worn part somewhere and you just dont notice it intil ur drivin. give it a look over an let us know your findings
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Postby BobS » Wed May 19, 2010 11:27 am
gobigorgohome wrote:tie rods would be a good start. also check steering linkage and all steering arms/rods. there could be a worn part somewhere and you just dont notice it intil ur drivin. give it a look over an let us know your findings
Also could be the alignment/toe in settings.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
