Rag joint kit
Rag joint kit
Postby bgilbert » Sat Jun 12, 2010 1:02 pm
Ok the steering coupler or rag joint that is.. Connects the steering shaft to the steering box on the frame. Anyone know if this is still available through Dodge? Also what does the kit consist of? Price? That coupler or rag joint on my new 89 Ramcharger is shot. Not going with the overpriced Borgeson.
Bill Gilbert
bgilbert
Re: Rag joint kit
Postby FRadisi » Sat Jun 12, 2010 2:35 pm
I've seen a kit available through Summit, JC Whitney, Borgeson, and a few other places I can't remember. I'm not sure if it's still available through Dodge or not. Try checking O'Reilly's as well.
FRadisi
Re: Rag joint kit
Postby PToombs » Sat Jun 12, 2010 5:12 pm
I replaced all the pieces of the coupler on mine 4-5 years ago. It was about 35-40 bucks. Trick is to find a rubber boot that seals to the shaft and goes over the box. The factory seal is a piece of crap, if you don't have the special tool to crimp it correctly, it'll leak and will rust in there again.
Re: Rag joint kit
Postby PRINCETON_JAKE » Sat Jun 12, 2010 6:56 pm
you can get them at most parts stores, Dorman (help) sells the rag joint kits.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Re: Rag joint kit
Postby RumbleFish » Sun Jun 13, 2010 8:36 am
i thought the rag joint was the disc like coupler further up on the steering shaft? i bought a kit from the dealer to rebuild the steering coupler near the gear box and it was like $12 or so. i wouldnt bother to rebuild it on a 4x4 truck though. they seem to tear them up plenty quick, so for my w100 i plan on making my own u-joint shaft. there is a how to over on ramchargercentral.
Re: Rag joint kit
Postby PToombs » Sun Jun 13, 2010 5:33 pm
Jeff's right, the rag joint is the rubbery disc up above. If you rebuild the coupler box, don't be cheap, buy everything. It doesn't do any good to buy new shoes and the spring if the box is worn out.
Re: Rag joint kit
Postby Begle1 » Sun Jun 27, 2010 12:23 pm
I packed my coupler full of grease. That should help keep water out, no? Especially if you use waterproof grease?
Re: Rag joint kit
Postby PToombs » Sun Jun 27, 2010 5:56 pm
Uh, no. :sad: When the water gets in it will work it's way down, waterproof grease or not. It may help it last longer than regular grease, but I'd try to keep the water out. Although with you being in Cali and all, your water probably doesn't have nasty road salt or calcium chloride mixed in it. Maybe this is more my opinion than fact, but you can't go wrong to cover it.
Re: Rag joint kit
Postby PJ 3 » Sun Jun 27, 2010 7:08 pm
When I bought my truck new in 1992 the steering coupler lasted about 4 years and had to be replaced. ( Ya I live in salt country :x ) I installed a rubber boot over the new installation and it lasted until last year, went heavy on the grease to......I tore it out and went with a borgenson ! The rubber boot and grease helped mind you !
Pete
1992 W250
PJ 3
Re: Rag joint kit
Postby BobS » Mon Jun 28, 2010 3:51 am
Dodge & GM trucks all had the rag joint mounted at the steering box from about the time they eliminated the one piece column and implemented the government required collapsible steering system. Dirt, road grime and salt was never an issue. BTW, Dodge used a wire mesh reinforced laminated rag joint at this time. Then Chrysler engineering in the late 70's or early 80's using their engineers of infinite wisdom decided to put the unit on upside down from the almost flawless way it worked in the past. The rest is history.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: Rag joint kit
Postby bgilbert » Fri Sep 10, 2010 7:31 pm
Sorry for the bump. Here's the part number for the steering coupler rebuild kit. Surprisingly it was in stock and readily available. Said he's usually got 4 or 5 in stock, but was down to his last one. I would've bought a couple for the SOP crew if they did. MOPAR 4443436-AC. That was on the receipt, I believe the package had a 1-0 prior to the part number. It was $12.35 list. IMO, as long as you don't have 35" tires and wheel the crap out of your truck, a stock coupler rebuild should last for years. You can rebuild it quite a few times for the price of the Borgeson. To each is own on that though. I know Matt Bales has 35" tires, but doesn't wheel his 4wd 90 CTD, and his coupler is holding up fine to a stock rebuild. So Jeff, your Ramcharger should have excellent steering soon haha.
BTW, BobS, I can see what you're talking about on my 74 Dodge W300. It's original, mounted the opposite our 89-93's are, and is still very solid.
bgilbert
Re: Rag joint kit
Postby PToombs » Sat Sep 11, 2010 6:08 pm
Bill, what exactly comes in the kit? I paid about $30 for the whole thing to replace everything from 1 shaft to the other.
Re: Rag joint kit
Postby bgilbert » Sat Sep 11, 2010 7:21 pm
PToombs wrote:Bill, what exactly comes in the kit? I paid about $30 for the whole thing to replace everything from 1 shaft to the other.
I knew I shoulda taken a picture of it. You get: 1 'crimp on cover' (supposed to hold the rubber seal onto the coupler). 1 seal, 1 'cross pin' (presses into the steering shaft), 1 roll pin (holds coupler to steering box nub), then inside the coupler is 1 metal clip, and 2 hard square looking metal pieces lol. Finally a very small roll pin, so to speak, that you tap into the side of the coupler. Keeps the coupler from coming off the steering shaft. Basically, a rebuild kit Pete! :lol: See what I mean about I should've taken a pic lol.
With the help of a press or vise, heat from a torch, roll pin punches, and a couple large pry bars it's an easy job. The hardest part I felt was getting the coupler off the steering box and then trying to 'crimp' the silly seal retainer on the coupler. That last part I didn't really get accomplished. Looks like I'll be looking for a good boot.
bgilbert
Re: Rag joint kit
Postby BobS » Sun Sep 12, 2010 5:16 am
Anybody tried to see if you can put it on upside down like the old way? It may work on the 92 & 93 with the removable upper flange.
BobS
89 D350 Stock
BobS
Re: Rag joint kit
Postby PToombs » Sun Sep 12, 2010 6:17 pm
Bill, that's about what I thought. You should have bought the box too. It gets worn inside. The kit will help, but in my experience it will still have play. I threw the cover and locking tab away. It's almost impossibe to get it on and to stay without the factory crimper. I got a rubber boot and put on mine. It seals to the shaft and goes over the box down to the round part, where I have a hose clamp. Works good so far! 8)
