frame swap questions.
Postby diesel freak01 » Wed Jun 30, 2010 7:09 am
ok so finally i have found a frame to put under my truck thanks to Mark. i have a few questions as to wha ti should upgrade while im doing it. i have already decided to do the kdp since it will be out anyways. i wanna do the things i should while its eeasy to get to but i also dont wanna have it apart for a month getting stuff done i would really really really like to have it done in a weekend, but if not no biggy.
so here is my request: make some suggestions of what i should do while i have it apart. i already have a lp to install, and i have new brake lines front to rear on my truck now so i will just transfer them over. anything else you guys can think of? thanks guys!
1993 d350 ctd drw 2wd auto
diesel freak01
Re: frame swap questions.
Postby TRENDZ » Wed Jun 30, 2010 1:33 pm
You remind me of me. I did all the things that were easy to do while it's apart... kdp, rear main seal, piston lp, large fuel lines, headgasket/valve job, brake lines, exhaust, etc....
TRENDZ
Postby diesel freak01 » Wed Jun 30, 2010 1:44 pm
thats one thing i am curious about i had thought about bigger fuel lines while im there but what size do i need? is 1/2 too big for me. or is it not gonna hurt a thing and just be over kill? and what line do i need to get or does it matter as long as its fuel line?
diesel freak01
Postby TRENDZ » Wed Jun 30, 2010 7:44 pm
The only down side of big lines that I can think of would be the fact that if you run it out of fuel, you have a lot more air to bleed out of the system.
TRENDZ
Postby diesel freak01 » Thu Jul 01, 2010 4:05 am
i never ever run it out of fuel. she gets down to 1/4 tank im stopping at a station
diesel freak01
