Was lucky last night . . .
Postby BC847 » Sat Oct 27, 2012 10:41 am
Scheid 6x0.016" EDM. I've beat the crap out of these things.
I must have done a good deed as God saw fit to not have the thing come apart while the engine was running.
Ya reckon a stock injector next to five 6x0.016" injectors would cause a problem with thoughtful running till I can get a replacement?
Re: Was lucky last night . . .
Postby DodgeFreak » Sat Oct 27, 2012 11:00 am
I don't think it would hurt any thing, ih told one of our drivers to run a truck with a bad injector for 5 days until they could get to it...and it was missing when it ran.....
Postby Tacoclaw » Sat Oct 27, 2012 11:43 am
Daaaaaaaayuuuuuuuum! I'd say you did, though you shoulda made a run down the strip with it like that, woulda been a quick way to know if you needed more fuel or not. :mrgreen:
Postby BC847 » Sat Oct 27, 2012 11:47 am
I'm afraid I killed a LOT of mosquitoes driving it home. Close to 25 or so miles. :shock: :oops:
Postby fatty » Sat Oct 27, 2012 3:19 pm
Weird. That's the second Scheid 6x16 I've seen split exactly like that.
Postby oldestof11 » Sat Oct 27, 2012 3:53 pm
Wow! Good thing you caught that! I would at least send a boroscope (sp?) In to see what damage might have been done to the piston.
Postby dazedandconfused » Sat Oct 27, 2012 6:05 pm
oldestof11 wrote:Wow! Good thing you caught that! I would at least send a boroscope (sp?) In to see what damage might have been done to the piston.
I agree i would be afraid it melted a piston some.
Postby BC847 » Sat Oct 27, 2012 7:31 pm
No apparent damage to the engine. It just went down on power and started killin skeeters. In tracking down the issue, with the engine idling, I cracked each of the injectors noting if it made a difference . . . #5 made no difference. The exhaust was presenting heavily with a white fog. Pulling #5 out found it wet with raw fuel.
I've just now temporarily stuck a stock/OEM injector that I had in there and it runs just fine. There is an odd knock/tap that I suspect is due to the well advanced injection event timing I've been running with the 6x16s.
I'm gonna have to retard it some.
I wonder if this is a sign of potentially similar issues with the remaining injectors. :?: :shock:
Postby soggy » Sat Oct 27, 2012 7:52 pm
BC847 wrote:No apparent damage to the engine. It just went down on power and started killin skeeters. In tracking down the issue, with the engine idling, I cracked each of the injectors noting if it made a difference . . . #5 made no difference. The exhaust was presenting heavily with a white fog. Pulling #5 out found it wet with raw fuel.
I think so.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby earthdad » Sat Oct 27, 2012 9:02 pm
Curious why that would happen. Found this link to some materials research of injector nozzles. Didnt read it all yet, maybe be of some interest.
Something to do with the rough microstructure of edm leading to stress failures, it did split about center of orifice ?
http://www.osti.gov/bridge/servlets/pur ... 027862.pdf
earthdad
Postby dazedandconfused » Sun Oct 28, 2012 6:08 am
I would pull them all and have them checked.
Postby Tacoclaw » Sun Oct 28, 2012 8:24 am
Just get one new injector, then feed some sand down the intake while the engine is running. It'll radius the edges of any potential cracks that may be starting and keep them from getting worse. Hell, if what earthdad says is true, you may want to feed some sand through your injection system too, it'll help smooth out the roughness of the holes as it passes through them. I would put the sand in at the injection lines though, no use running it through your IP if it doesn't need it, it's already really smooth in there from the pics I've seen.
Postby earthdad » Sun Oct 28, 2012 8:50 am
Hes got a good idea. Baking soda may be a better option as it is a little finer than sand. :) BTW, I didnt conjure any of this stuff up. If the source I referenced was'nt true, I guess shot peening would be foolishness???
I deffinitely have much to learn bout diesel tech, and I think you guys have loads of knowhow and skill and I would'nt be where I am with my truck had it not been for some great advice. But I dont think I'm all that off on this.
So, even with my lack of experience, I agree, they should all be taken out and examined for stress fractures.
earthdad
Postby Tacoclaw » Sun Oct 28, 2012 12:13 pm
You're correct, it is much finer, but I question if it's actually resilient enough to make an impact on the steel itself. I think BC would be better off getting some normal sand, making a little pile in his driveway, then hammering on it until he gets the size that he needs.
On top of the customization this allows him in it's size, it would also save him a trip to the store since he could just go out and get any sand/dirt out of his yard.
I'm not questioning you or your sources, ED, I just have no beneficial knowledge to add to this so I'm doing what I know best. ;)
Postby earthdad » Sun Oct 28, 2012 12:31 pm
I gotcha :roll: It just takes some time to see member characters develop within the limitations of black and white text and a few assorted smileys. By all means "do what you do best".
earthdad
