Just a big headache
Re: idiots
Postby dazedandconfused » Wed May 09, 2012 2:21 pm
ellis93 wrote:For the speedo to work,the computer's gonna have to come on.
Comp Grounds are in connector 3 (color idk) pins 19 solid black
Comp ignition on power is in connector 4. Pink wire pin 18.
These two were mia. On the white wire for the tach is it in the big main bulkhead or the little white one under the hood? Im splicing wires in as we speak and wrapping the harness back up.
Re: idiots
Postby ellis93 » Wed May 09, 2012 4:10 pm
Main one. There should be several plugs on top(like the cruise,wipers,abs....)Then one on the bottom that bolts in the block. That wire should be in the bolted one.
Re: idiots
Postby dazedandconfused » Wed May 09, 2012 4:35 pm
Ok there are 2 whit wires. One runs to brake lamp relay the other to tge plug on ps pump
Re: idiots
Postby ellis93 » Wed May 09, 2012 7:57 pm
Andy,if you can,take a breather and wait till tomorrow afternoon. I'll get you a premo pic of the exact wires position ;)
Re: idiots
Postby dazedandconfused » Thu May 10, 2012 12:33 pm
It got dark on me so i stopped messing with it yesterday.
Well good news i p :mrgreen: ut it back together and the speedometer works now!
Re: idiots
Postby ellis93 » Thu May 10, 2012 3:28 pm
good deal!
I struck out on a vortech harness,so no pic :grrr:
The harness you have there,does it still have the coil plug? If it does hook that grey wire to the tach prong on that HEi and see it that tach works.
Re: idiots
Postby dazedandconfused » Thu May 10, 2012 3:34 pm
Nope all that stuff is gone. Big thanks Ellis for all of your help it means a great deal to me.
Re: idiots
Postby dazedandconfused » Thu May 10, 2012 3:51 pm
:alien: :mrgreen: tach works!!!!!
Re: idiots
Postby ellis93 » Thu May 10, 2012 4:03 pm
Great! That dude ought to be real happy, happy enough to had you a stack of cash an inch tall. :lol:
Re: idiots
Postby dazedandconfused » Thu May 10, 2012 4:57 pm
He called asking what was taking so long today. He was suppose to order a water pump pulley and fan weeks ago and i haven't seen them. Turns out he forgot and thats what ive been waiting on.
Re: idiots
Postby dazedandconfused » Tue May 22, 2012 4:44 pm
Well its together but the dang oil psi gauge won't work now. When I plug in the new sender it goes wacko then to zero and check gauge light comes on.
It's a sharp truck screaming for a Cummins.
Re: idiots
Postby ellis93 » Tue May 22, 2012 6:12 pm
dazedandconfused wrote:Well its together but the dang oil psi gauge won't work now. When I plug in the new sender it goes wacko then to zero and check gauge light comes on.
Always something aint it :lol:
Re: idiots
Postby dazedandconfused » Tue May 22, 2012 6:20 pm
Oh yeah im thinking about just putting a manual gauge in it
Re: idiots
Postby ellis93 » Tue May 22, 2012 6:47 pm
Sounds like a good idea to me. At this point I'd say you taken enough! :lol:
Re: idiots
Postby dazedandconfused » Sun May 27, 2012 1:43 pm
Have i ever mentioned i hate Chevrolet gas motors? Lost the oil pump today installing the mechanical gauge she started ticking. I shut it off and pulled passenger valve cover and it's just barely dribbling oil. :evil: So tomorrow im going to try and get the pan off with the motor in the truck. Wish me luck I'm going to need it.
