drag times
Re: drag times
Postby Hansen01 » Sun May 20, 2012 8:49 am
Hmm least someone can see it :D
Under construction...
Hansen01
Re: drag times
Postby JustinRhodes » Mon May 21, 2012 6:02 pm
8.39 in the 1/8 at 82
13.04 in the 1/4 at 104 8) I will break into the 12s and lower in the 8s
JustinRhodes
Re: drag times
Postby Tacoclaw » Mon May 21, 2012 6:20 pm
Dang!!
Nice runs, Justin. Is it getting scary to slow that thing down yet? :lol:
Re: drag times
Postby JustinRhodes » Mon May 21, 2012 6:24 pm
Tacoclaw wrote:Dang!!
I have an extremely hard time stopping for the first turn to get off the track lol, but I'm hoping with some more trans parts so i can leave harder to break into the 12s, and alot lower 8s.
JustinRhodes
Re: drag times
Postby 1STGENFARMBOY » Fri Jun 08, 2012 9:58 pm
Well i got bit tonight, me and the boy went to the local 1/8th to watch a few runs, when
we were leaving this dude pulls up on a 4 wheeler and says ( do you want to run it ) i say
i didn't pay, he says i own the track and want to see it run.
sooooo i pull up to the tree and fell a sleep for a while.
reac 1.405 :lol: :roll:
60ft 2.36
330 6.57
594 9.55
1/8th 10.19 @ 70 mph
does this mean if i could stay awake at the tree i could run 9.1 and maybe boost it a bit and be
in the high 8's
forgive me guys it's been 22 years since the last time i went down the track
Darwin
Re: drag times
Postby BC847 » Fri Jun 08, 2012 10:12 pm
Your reaction-time has zero impact on the ET.
It's been my experience that, to knock off a tenth of a second, each comes at a steeply rising cost. Emphasize STEEP.
I laugh at myself when I think of the crap I've busted taking this last tenth off to get to my current 8.05 in the eighth (@ 250ish feet elevation).
Good luck.
Re: drag times
Postby oldestof11 » Sat Jun 09, 2012 7:08 am
Dar, did you go to Havana? I will be down there June 30th with a few guys for a diesel only bracket race. As of right now, with 15 trucks entering,winner geta $300.
Re: drag times
Postby 1STGENFARMBOY » Sat Jun 09, 2012 2:35 pm
Thanks David...as i said i'm rustier than a northern 1st gen.
Jon ..no i went to Benton ILL (I 57 raceway).
i feel like i could cut off 1maybe 2 tenths as i did a zero bosted launch and went in 2 WD.
anyhooooo it's not really important as i really have to keep my truck going down the road
and keep it where i can tow pretty heavy, and normaly fast race truck don't work well with
a heavy goosneck.
Dar
Re: drag times
Postby oldestof11 » Sat Jun 09, 2012 3:09 pm
No you cant go faster in 2wd. LOL! I run high 15s in 4wd and 17s in 2wd.
Re: drag times
Postby m880cummins » Sun Jun 17, 2012 8:52 am
I ran a best of 16:22 Friday night!
SUNY Maritime Class of 2017!
m880cummins
Re: drag times
Postby oldestof11 » Mon Jul 02, 2012 6:18 pm
M880, nice times!
Here are 3 of my runs from this weekend.
I have open front and rear diffs. I launched at 3200-3500 rpms with no substantial load.
http://www.youtube.com/watch?v=3AWbEfV8HLY&feature=plcp
http://www.youtube.com/watch?v=X33IY27T ... ontext-cha
When the truck drops and lifts, 2nd to 3rd gear change without prejudice. LOL! This is the only run with the bracket race. The other 2 are test runs.
http://www.youtube.com/watch?v=9Y7eFUQJ ... ontext-cha
Re: drag times
Postby m880cummins » Tue Jul 03, 2012 5:49 am
I've been tempted to try a 4wd launch...I'm just not sure how all of the rotating parts will feel at 90mph..
I noticed I can't pull hard above 2500rpms. I guess I need a bigger lift pump. From 0-60 your azz is planted in the seat then the tailpipe clears and from 60-90 it takes forever.
Charlie
m880cummins
Re: drag times
Postby RumbleFish » Tue Jul 03, 2012 6:20 am
BC847 wrote:Your reaction-time has zero impact on the ET.
QFT! Everybody seems to think rt affects et, especially on the internet.
Re: drag times
Postby oldestof11 » Tue Jul 03, 2012 6:15 pm
But in bracket racing, isn't that important?
Re: drag times
Postby BC847 » Tue Jul 03, 2012 6:29 pm
oldestof11 wrote:But in bracket racing, isn't that important?
I'm still figuring out Head's-Up racing. :roll:
I've got two or three time-slips around here somewhere that shows I won, yet, my opponent was faster AND quicker at the finish line.
It seems that perhaps I had a better RT, a better 60' with a better 330', etc, compared to my opponent. I suppose you could say I had a better hand at the end of the strip.
EDIT: Found one:
I know in bracket racing, you predict your ET and try to get as close to it without actually going quicker.
Y'all are making me want to do a Google. Screw it, I'm tired. Spent too many hours on a roof installing refrigeration pipe insulation. I'm babbling . . . . . . . .
Return to Competition
