Dual feed VE
Postby ford69557ci » Sat Nov 17, 2007 12:41 pm
if i can talk the local guy with the dyno into lettin me run on a sat i will have some numbers but usually he is only open on weekdays
ford69557ci
Postby meby » Sat Nov 17, 2007 2:33 pm
KTA wrote:I am waiting on you guys to do the R&D for a change and smash my records that way I have an incentive to see whats left in this thing, right now I have other more interesting projects. 8)
I have never been in this to break the all time records for the VE. Just enough to make my local Bosch rebuilder eat there words. Lets say 400hp. But for now i am going to have pull back for a while. I decided to go back to school and get a degree. Meaning, I wont be able to drive the truck and go to school both. I just put it in the paper today to sell. Once I am out of school I am sure I'll be getting another truck again.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby DTanklage » Sat Nov 17, 2007 4:33 pm
me either
i still have to tow with mine...
sorry to hear you cant afford to keep your truck
how did that thing end up with a 12v ve motor anyways?
don
DTanklage
Postby ford69557ci » Sat Nov 17, 2007 4:38 pm
im buyin an 04 to tow with as much as i dont like common rails. yeah how did that truck end up with a ve motor ???
ford69557ci
Postby cummins king » Sat Nov 17, 2007 8:07 pm
a electric fuel pump that pumps 40gph at 100psi is that crap, good or really good
what does the areomotive a1000 pump
thanks
93 4X4 auto
cummins king
Postby DTanklage » Sat Nov 17, 2007 9:34 pm
600 lbs (approx 80 gals) per hour @ 45 psi
DTanklage
Postby cummins king » Sat Nov 17, 2007 9:37 pm
so then i guess its half desent
93 4X4 auto
cummins king
Postby ford69557ci » Sun Nov 18, 2007 2:32 pm
an a1000 is a great pump its what KTA runs. go to www.aeromotiveinc.com and check out some of the other killer pumps they offer. they have one pump in thier catalog that will keep me from havin to buy 2 king sumos.
ford69557ci
Postby meby » Sun Nov 18, 2007 3:15 pm
don
The truck came with a 24 valve that fried 3 injection pumps in less than 60,000 miles. The guy got really ticked and pulled the 24 and put in a 12. I just found out recently that they even had fuel pressure gauge's and regularly swapped out lift pumps to no avail. hows that for weird? :o
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby DTanklage » Sun Nov 18, 2007 8:19 pm
not weird at all...
if you read the 2nd gen forum over at tdr all those guys with the vp-44(?) and electric lift pumps are having all sorts of reliability issues
its just weird that the previous owner didnt do his homework and put a more desired 215hp motor in it
more desired by some...i know, some of you guys are die hard ve drivers
DTanklage
Postby Begle1 » Sun Nov 18, 2007 8:28 pm
He probably had the VE for cheaper, or (more likely) it was probably readily available.
Postby ford69557ci » Sun Nov 18, 2007 9:57 pm
i wanna tear apart a vp44 and figure out why it can move so much more fuel than a VE its still a rotory so WTF is the difference?
ford69557ci
Postby DTanklage » Sun Nov 18, 2007 10:17 pm
i was thinkin the same thing
then thought about it some more...
if i was gonna switch pumps, i wouldnt want an electric one
but maybe something you learn in the 44 can be applied to the ve?
DTanklage
Postby JD730 » Mon Nov 19, 2007 4:51 am
I saw photos of a VP44 tore down and laid out real nice on a bench. Completely different from a VE. It's a radial piston similar to a roosa master/stanadyne, only with electronic controls.
Mike
The "Rattle Box"
JD730
Postby ford69557ci » Mon Nov 19, 2007 11:43 am
i have a dismantled 6.5 chevy stanadyne pump and if the vp is as lousy as those no wonder they always go out
ford69557ci
