new springs
new springs
Postby VanillaGorilla » Thu Jun 28, 2012 4:05 pm
So my truck plowed most of it's life and the front springs are negative arched. Since i havethem i was wondering if anyone has ever used front springs from a half ton 4 inch lift? Sound sketchy?
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
Re: new springs
Postby ahale2772 » Thu Jun 28, 2012 4:10 pm
I used 2 inch skyjacker leafs out of a 85 gasser for 2 weeks.
sagged in that two weeks to the point that I ripped them out
Re: new springs
Postby VanillaGorilla » Thu Jun 28, 2012 6:51 pm
Good thing I got 2 more inches to work with?
VanillaGorilla
Re: new springs
Postby CumminsPower59 » Thu Jun 28, 2012 7:11 pm
The problem with that is when they sag, they get longer. Long enough in fact that the shackle will hit the frame. Shoot, sagged out stockers almost hit the frame as is. All springs settle and sag eventually. I seen 2" Skyjackers new at $300ish a pair for the heavier capacity versions. Springs are like boobs, some sag faster than others ;)
