Crooked Steering wheel
Re: Crooked Steering wheel
Postby jdaivs1 » Sun Jul 15, 2012 1:22 am
Didn't have my front end aligned but when my steering wheel was not straight it was because my power steering bracket was cracked. Happen twice.
93 w250 auto, fuel screw turned in
jdaivs1
Postby 93DodgeCummins » Sun Jul 15, 2012 9:33 pm
I know this sounds like a dumb quesiton. Is it an easy crack to find or do you have to know just what you are looking for?
93DodgeCummins
Postby jdaivs1 » Thu Jul 19, 2012 12:44 am
first one I had to really look for. The second one I could see pretty easy.
jdaivs1
Postby jdaivs1 » Thu Jul 19, 2012 12:49 am
first one I had to really look for. The second time it happen I could see it pretty easy and it was in different place. If this happens to be your problem I saw somewhere that there is a brace/bracket to help prevent this problem, just can't remember where at the moment but I do want to get one.
jdaivs1
Postby jdaivs1 » Thu Jul 19, 2012 1:04 am
just saw this on another forum bc847 posted it. Not sure if it is the same bracket I was referring to: VHappens to an alarming number of first gens, mine included.
If I'm correct with the model, there's a reinforcement bracket that Dodge used on the Ramchargers that attach's to the inside of the frame, opposite the steering box mounting bracket.
Not only does it help lessen the stress on the bracket, it also helps reduce this . . . . . Maybe BC847 can tell us more Part #?
jdaivs1
Postby BILTIT » Thu Jul 19, 2012 5:49 am
Derek B.
BILTIT
Postby 78fordf150ranger » Thu Aug 23, 2012 9:18 pm
I'm having the same problem with my truck after I did the cross over.
78fordf150ranger
