My Flatbed Swap
My Flatbed Swap
Postby Burritoboi5 » Sat Jul 28, 2012 9:16 pm
Well I decided I want to flatbed my truck.
Here's the truck as she sits now
I picked this up last sunday
And I want a wooden bed so I cut out the diamond plate deck
Got rid of some of the headache rack too.
Then sandblasted and primered it.
Hoping to maybe pull the bed off tomorrow. I also need another day to finish spraying the black paint on the bed. I ordered 2 inch red oak for the bed, and am edging it in 2 inch x quarter band metal that I welded on already. More pictures to come as it progresses.
New wheels should be in this week....tire place screwed two of mine up and couldn't find replacements so they bought me a new set. Also putting a 3 inch spacer in the rear to avoid tire rub under load.
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby bmoeller » Sun Jul 29, 2012 5:18 am
I highly recommend adding skirting on the flatbed. Will lose plenty of mileage. My 97 lost 4-5mpg with the aluminum one I had. I still prefer a flatbed, but that kind of mileage hit is more than I want again. Since I don't really do any farmwork anymore, and spend most of my time pulling a bullrack or being in the shop, I don't need one like I used when I was.
Have the same rims on my truck now. :D Kinda partial to the Classic Alcoas, but these were priced just right, and I wanted something a bit different. Plus, I can get my hand in and remove the inner valve stem cap without any trouble. :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: My Flatbed Swap
Postby Burritoboi5 » Sun Jul 29, 2012 6:50 pm
Why the the strong preference to skirting? Just curious, I rather like the look of the slim bed. I will be adding two tool boxes in front of the wheels in any case.
-Steve
Burritoboi5
Re: My Flatbed Swap
Postby bmoeller » Sun Jul 29, 2012 7:45 pm
Just because of the crappy areodynamics of it. Very dirty air that kills the mileage.
May need to tweak the filler as well. Mine didn't have enough fall, so I had to use wood blocks up front. :/
bmoeller
Re: My Flatbed Swap
Postby KurtzN1 » Mon Jul 30, 2012 10:23 am
Very nice progress so far. I'd also recommend skirting for aero at least a little.
KurtzN1
Re: My Flatbed Swap
Postby Burritoboi5 » Mon Jul 30, 2012 2:05 pm
Got the flatbed frame all painted today. Pulling the bed off the truck tonight.
Burritoboi5
Re: My Flatbed Swap
Postby Burritoboi5 » Mon Jul 30, 2012 7:23 pm
Well it took about an hour and a half, but I got the bed off. Maybe try to sandblast and prime it tomorrow if I have time.
Image'
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby PToombs » Tue Jul 31, 2012 4:25 pm
Loks like somebody is horny! :lol: You should have those facing the other way! ;)
Re: My Flatbed Swap
Postby oldestof11 » Tue Jul 31, 2012 6:02 pm
I have been thinking about putting a flat bed on my truck..
Re: My Flatbed Swap
Postby Burritoboi5 » Wed Aug 01, 2012 7:23 pm
Thanks gents.
Well I got it all sandblasted, dropped the tank, pulled the shocks, the whole shebang.
Then primed/sealed/and undercoated with truck bedliner.
I also went ahead and redid the rear brake lines, hard and soft. Just left the ABS crap out. I mounted up my horns, and ran some of the wiring. Tomorrow I hope to finish my wiring and mount my rear lights as well as get some more woodworking done.
Here's what I have, just rough cut red oak 2 inch actual thickness.
After a lot of sanding with the 4 inch belt sander I get this....
That's with two coats of tung oil. Going to apply 6-8 before it sees the light of day.
And here's a closeup. The pictures don't do the wood justice.
Kriv
Burritoboi5
Re: My Flatbed Swap
Postby ellis93 » Wed Aug 01, 2012 7:56 pm
Beautiful! I love the look of oak wood,I'd tear up the first time I slid something in there tho :lol:
Re: My Flatbed Swap
Postby Burritoboi5 » Thu Aug 02, 2012 8:25 pm
Yea haha I'll probably carry a moving blanket with me to keep her looking sharp atleast for a bit.
Today I was able to complete all the wiring in the ass end of the truck. Got my new lights mounted and functioning as well as auxilary reverse lights. Also got my trailer wiring and running lights loomed and ready to go for the flatbed. I bled the brakes while I had someone to give me a hand. And put in another board. Lastly, I was able to cut my stack down to the proper height. It needs more finish grinding and paint as well as provisions for my flame thrower.
Tomorrow I will fix the cab corner and primer the rear of the truck so I can prep it for paint before the bed goes on. Then hopefully knock out some more of the wood and start in on my exhaust. If all goes well I would like to put the bed on saturday.
-Kriv
Burritoboi5
Re: My Flatbed Swap
Postby little doug » Thu Aug 02, 2012 9:56 pm
The bed is looking good ! I also like your M715 ! I see it says cummins on the side . :grin:
93 W250 LE extra cab, 5 speed,warn winch, tach,piro,boost gauges. Gov.spring and fuel pin... Play truck
-91 W350 LE reg cab chassis.exxxxtended 175"wb, banks intercooler,on board air ,5 speed,... Work truck
little doug
Re: My Flatbed Swap
Postby Hansen01 » Fri Aug 03, 2012 11:14 am
Flamethrower? Lets see some pics of that when you get to it :twisted:
Under construction...
Hansen01
Re: My Flatbed Swap
Postby cmann250 » Fri Aug 03, 2012 1:11 pm
Hansen01 wrote:Flamethrower? Lets see some pics of that when you get to it :twisted:
He had a thread titled something like "Super High EGTs" a while ago
