Steering Box Input Cover Removal...Help
Postby 93DodgeCummins » Fri Sep 21, 2012 12:06 pm
What tool would i use to get this front cover off? Is there any easy ways to get it off? The seal is bad and i need to replace it...
http://s1255.photobucket.com/albums/hh6 ... ad0253.jpg
93DodgeCummins
Re: Steering Box Input Cover Removal...Help
Postby BILTIT » Fri Sep 21, 2012 12:23 pm
Punch and hammer after lots of penetrating oil/spray.
Derek B.
BILTIT
Postby 93DodgeCummins » Fri Sep 21, 2012 12:44 pm
On the outer tabs or on the inner 2 holes
93DodgeCummins
Postby BILTIT » Fri Sep 21, 2012 3:28 pm
Outer tabs, inner two holes are for adjusting bearing preload.
Derek B.
BILTIT
Postby 93DodgeCummins » Fri Sep 21, 2012 3:57 pm
Well it must really be on there. The punch knocked of the tabs Clean off
93DodgeCummins
Postby PToombs » Fri Sep 21, 2012 5:40 pm
Warm it up with a torch, you're going to change the seal anyways. The hex is the locknut, loosen that, then you should have a spanner for the 2 holes. I have used 2 punches with a bar in between, but it's a bitch. The center piece (with the 2 holes) unscrews out, the shaft will come with it, be careful. You should be able to push the shaft back as you remove it so it stays. I didn't as my shaft was rusty and I changed the whole input assembly with one from my donor truck. When you assemble it, screw it back in until snug, then back off 1/8th turn. Drive it and see if it feels loose or tight, then readjust if necessary. If it feels sloppy, turn it in a little, tight, turn it out.
Postby Bogie » Mon Sep 24, 2012 12:42 am
This TSB will help
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
Postby 93DodgeCummins » Mon Sep 24, 2012 5:10 am
I got it with a big pipe wrench. Thanks for help. :D
93DodgeCummins
