New from Houston area
Stop in and say hi
Postby quiksilver » Wed Oct 31, 2012 8:56 pm
I've had my 1991.5 w250 for a few years but just now focusing on the performance end of it all. Went for the facelift after i got it. Just have the basics done on it as far as performance, 4" tbe, dennyt stg II and screw turned up. The VE just recently started leaking like a sift. Rebuild or P pump the goat?
quiksilver
smoke screw?
Re: New from Houston area
Postby ellis93 » Thu Nov 01, 2012 3:39 am
Welcome! Nice truck
Postby tampabayBill » Thu Nov 01, 2012 6:06 am
Welcome !! I'm in Beaumont and get over to the League City area often, where are you ?
Twins coming soon!
tampabayBill
Postby JD91 » Thu Nov 01, 2012 3:12 pm
welcome!!! nice to see some more Texans on here
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Postby oldestof11 » Thu Nov 01, 2012 4:05 pm
Rebuild is not expensive, the p pump swap is going to run you up a bit.
Postby quiksilver » Thu Nov 01, 2012 7:08 pm
I am just north of Houston in Conroe. Thanks for the welcome guys! I think i am just going to rebuild the ve for now. Maybe one day haha!
quiksilver
smoke screw?
Postby dazedandconfused » Fri Nov 02, 2012 2:57 am
Welcome
Return to Welcome
