Crew Cab Frame and GVW?
Postby sxd217 » Tue Nov 27, 2012 5:40 pm
Can anybody confirm the GVW is of a 85 Dodge 350 crew cab 8ft bed dually is? I am thinking it is 10,000 lb
Does anybody know whether there are any differences between the frames of a 85 350 crew cab 8ft bed dually verse single wheeled?
Why are the single wheels crew cab only rated for 8510 lbs? the newer trucks are rated as high as 10,100 lbs for single wheels?
Thanks
sxd217
Re: Crew Cab Frame and GVW?
Postby m880cummins » Wed Nov 28, 2012 1:59 pm
I'm not sure about a single wheel. My DRW frame has 7" high rails and a local single wheel has 6" rails.
I'll check my door post.
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby sxd217 » Thu Nov 29, 2012 2:30 pm
Thanks
The rails on my crew cab 8ft bed single wheel are 7"
sxd217
Postby DodgeFreak » Thu Nov 29, 2012 5:24 pm
the newer ones have bigger axles....d60 in 85 crew not sure if your talking newer crew cabs or pick ups in general but newer trucks had from dana70s to 80s. and some dana or something or other lol..
Postby sxd217 » Thu Nov 29, 2012 9:41 pm
what I am really curious about is if a 85 Dodge crew cab 8ft bed dually is rated for 10,000 GVW, what are the differences between the dually and the single wheel (besides the extra set of wheels) that it is only rated at 8,510 GVW
So DodgeFreak you are saying the single wheels had dana 60's
Did the Duallys have dana 70's?
Could I swap the rear axle to a dana 70 or 80 (with the appropriate spring pack) and could it in theory be rated for 10,000 lb GVW?
sxd217
Postby sxd217 » Fri Nov 30, 2012 10:18 am
this gives me a little more insite
viewtopic.php?f=2&t=5143
sxd217
Postby DodgeFreak » Fri Nov 30, 2012 11:14 am
wait and see if Mark Nixon will respond he's the man on this stuff.
Postby Mark Nixon » Mon Dec 03, 2012 8:30 pm
My Crew Cab Dually longbed is rated at 10,000 GVW and the door sticker is still legible enough to read it.
There are some 9,000 pound SRW trucks out there, but all of those were pre-1986 that I am aware of and they all used Dana 60s under the rear.
Interesting to note on the SRW 9k trucks is that they did use the 5/8" studs with tapered seat, 1 inch(?) hex lugnuts, in lieu of the 1/2" 13/16" lug nuts.
The Crew Cab frames are all pretty much the same frame from 1981-1985.
The Crew frames from 1973 through 1980 are also the same strength and height, but the rear of the frame is shaped a little different over the rear axle, IIRC the difference was that the later frames have a "shelf" for what I believe was to aid in putting a goose neck plate on the '81-up trucks.
AFAIK, from 1981-1985 all duallies got Dana 70s, as did all of the 1970s dually 1 tons.
Most VAN Chassis with DRW did NOT get a D-70! Those were Dana 60s with 70 tubes stepped down for the 60 center.
My Crew Dually is an '82 and it HAD a 70 under it, until I removed it to put an 80 under it (unfinished, BTW).
