ford69557ci wrote:well i already have the 4mm because thats what they offer off the shlef and i feel like pissin away money so i figured i would have them do a 4.5 since its really not much extra and if it works good that is just one more thing we will know. i have the 4mm in my test pump
ford69557ci wrote:on the low side of 520cc but thats with a rather high inlet pressure so i am tryin to get a seal to stay in or figure out somewhere else to put the fuel. also i met a guy on comp diesel and we are going to start retrofiting some high flow dv's from a military pump.
i gained 10cc with the custom cut valves so if the fuel can be burnt it might be a little more that 20hp?? and the pumps get tested on a test stand and to measure the flow that you would be seeing in the truck you flow it with the injectors your plannin to use.i dont even think you will see 20hp with costom dv's im thinking like 5hp gain, with all this hipe im going out toay and getting a couple pumps, not bad mr ford with the 520cc watch out second and third gens, did you make the fins on the vain pump bigger or did you leave then stock, and heres a nuby question how are you testing how much fuel your pushing out thanks
I have had it to 2500 thats the limit of the seal but i might have found this little double lip seal that thermoking uses on some of thier older ac compressors and if i can obtain a smaller version that might be my fix
