It doesn't sound like it is off time to me. It sounds like air, or injector problem..... or something internally of the pump is messed up.
But it did this before, correct? If so, then the problem is not with the pump.
93DodgeCummins wrote:Ran like a champ before. I figured out the problem. I took off the front timing case and removed the pump again. Turns out when i reinstalled the pump the key was was not perfectly lined up. So it ruined the key.... Making it off time...So i sent it off to have the pump timed for top dead center 1 so i can reinstall it and not have to worry as much about that little key i ruined. I feel like an idiot
93DodgeCummins wrote:So i sent it off to have the pump timed for top dead center 1 so i can reinstall it and not have to worry as much about that little key i ruined...
