ellis93 wrote:Luther Grimace wrote:I installed the injection pump one tooth advanced. I lined the 0 on the cam up with the C on the IP gear instead of the E. I then fully retarded my IP. What do y'all think the equivalent advance I have now?
One tooth advance is 10° advanc, thats 0 to E, if you then retarded the pump then you should have your timing a fuzz lower than stock. At least with the marks on my case thats how it would be.
Luther Grimace wrote:Things have been going eerily good. Well I have been brought back to reality. I got the radiator installed and the belt put on. Also got the power steering fluid hooked up. I backed it out side little it run for about 10 minutes and then all the sudden it started missing. Barely ran for a minute and then died. It was acting like ran out of fuel. So I checked the fuel filter and it was full. I then pulled the feed to the pump and it was flowing a lot of fuel. When I went to crank it again I cracked the fuel lines and airiated fuel was coming out and it didn't have near the pressure it should. It will normally squirt all the way onto the fender. Now it is just bubbling out. I feel like something in the pump is the problem. Also it is leaking fuel out the vent on the diaphragm body. Anybody got any clues? It is so depressing.
Luther Grimace wrote:What is the FFS? By the way I pulled the fuel solenoid out of the pump and tested it without that and it wouldn't crank.
