eyoung429 wrote:Your egt's will go higher with the 12cm depending on how you drive, the type of terrain and THE AMOUNT THAT YOU POST IN CAPS@!!!!!
burnt_servo wrote:eyoung429 wrote:Your egt's will go higher with the 12cm depending on how you drive, the type of terrain and THE AMOUNT THAT YOU POST IN CAPS@!!!!!
i wonder if he knows that typing in caps is considered yelling ?
flashgordon wrote:burnt_servo wrote:eyoung429 wrote:Your egt's will go higher with the 12cm depending on how you drive, the type of terrain and THE AMOUNT THAT YOU POST IN CAPS@!!!!!
WHAT!!!!!!!![]()
jK![]()
Flash
