Getrag Rebuild
Re: Getrag Rebuild
Postby ellis93 » Mon Feb 20, 2012 12:16 pm
All finished :mrgreen:
Re: Getrag Rebuild
Postby Mark Nixon » Mon Feb 20, 2012 1:18 pm
Is it noisy? :lol:
Ellis, we (I'm sure others agree) appreciate you going to all the trouble to document this with pics.
This definitely shrieks "Sticky!".
Re: Getrag Rebuild
Postby ellis93 » Mon Feb 20, 2012 1:36 pm
Mark Nixon wrote:Is it noisy? :lol:
Don't know,its not in the truck yet. Gotta get that big bastard pushed back in the shop first :lol:
Re: Getrag Rebuild
Postby Mark Nixon » Mon Feb 20, 2012 1:52 pm
Oh. :oops:
Well, are you going to do anything to the clutch so you can provide more scholastic progress? :mrgreen:
Re: Getrag Rebuild
Postby ellis93 » Mon Feb 20, 2012 3:12 pm
No,but I've got it off to get at the rear seal. I'm doing the kdp and 3200 spring and injectors and........crap I've spent so much right now I want to puke :yuck:
Well after 8yrs of no BIG issues :| gotta spend it sometime I reckon :lol:
Re: Getrag Rebuild
Postby Mark Nixon » Mon Feb 20, 2012 3:24 pm
With any luck, it'll be many more years for the tranny, after this.
Funny, but over the last 3 days, there have been 3 getrags croak around me. :lol:
I sold a bunch of cores a while back and I wish I had them now.
I could probably rebuild and sell half of them this week.
Re: Getrag Rebuild
Postby ellis93 » Tue Mar 06, 2012 7:31 am
Finally got the. Engine where it would fire off and the trans is quite as a church mouse 8)
Re: Getrag Rebuild
Postby Walter » Sat Mar 10, 2012 1:57 pm
Good post. My Getrag sounds like it's got a bad input shaft bearing, so I'll be pulling out the truck pretty soon.
Walter
smoke screw?
Re: Getrag Rebuild
Postby ahale2772 » Mon Mar 12, 2012 3:30 pm
feels good to beat a subject into the ground untill there is no way someone couldnt reference one of these threads and find the answer to their problem 8)
Re: Getrag Rebuild
Postby Exekiel » Sun Aug 12, 2012 6:44 pm
ellis93 wrote:I'm gonna try and fill in some more in the next couple of days of how to pull the syncros off the 1st and 2nd gear faces and some of the reassemble of the mainshaft. I may ask alex to edit his post on here with his preload measurements and pics off of his trans tread, would ya alex huh huh huh please. :mrgreen:
Thank You for documenting all this, I have rebuilt the getrag before but I learned a few things I didn't even know about. If You could please explain more about the part where You drive IN the synchros I will appreciate it, 2nd gear on mine will jump out if I don't keep My hand resting on it and it might be what You said above that it isn't fully engaged. I'm saving a copy of this thread for My personal file when You are finished with it, Thanks.
1993 f350 with a 5.9l ctd and getrag
Exekiel
Re: Getrag Rebuild
Postby ellis93 » Sun Aug 12, 2012 7:36 pm
I'm pretty much thru with it ;)
The driving on of the synchro is pretty much straight forward,being the roll pin holes are blind in the first and second gears I just pry them off and drive them back on with either a pin punch or a sacrificial socket of some kind. You WILL need to pay close attention to how it goes back on,watch that you do not bend the roll pin or synchro backing. Also depth is not an issue,basically once against the gear your good,lest it has been in my experience.
With yours jumping out of gear I'd look hard at the small teeth the collector engages. Look for any rounded edges,thats the number one cause of a manual trans to pop out of gear. People normally cause it by using the grind it till you find it approach. :lol:
Re: Getrag Rebuild
Postby ihredneck » Thu Apr 11, 2013 8:25 am
Great post!
Reading through, and collecting parts to do my G360, should I replace the needle bearings too?
All the master kits I've found do not include them and it seems that they should be replaced...
ihredneck
Re: Getrag Rebuild
Postby ellis93 » Thu Apr 11, 2013 9:01 am
ihredneck wrote:Great post!
They don't tend to give problems,only when ran low of lube will they need replacement. Basically if the needles are of a blue-ish color replace them,if not run them. Food for thought......if your needles go bad the the shaft and/or gear is gonna be screwed as well 90% of the time.
Re: Getrag Rebuild
Postby ihredneck » Thu Apr 11, 2013 8:27 pm
Ellis93 thanks for the tip!
Gonna go tackle it here soon hopefully
ihredneck
Re: Getrag Rebuild
Postby ihredneck » Fri Apr 12, 2013 6:30 am
Also, the synchros all look really good on mine. I never used the tranny, but was told it was starting to make noise is why it was pulled...probably input bearing. But, even though the rings look good, would it be best to change them out?
I personally like to do things when something is apart...I was just surprised at how good these look
ihredneck
Return to Transmission
