rear bench seat swap
both inside and out
Postby hager » Wed May 01, 2013 7:32 pm
http://i1285.photobucket.com/albums/a59 ... 7f2975.jpg
just ran across the seats in the junkyard curious to see if they fit in the back of my extended cab. the donor truck is a 97 Ford extended cab
hager
Re: rear bench seat swap
Postby CumminsPower59 » Wed May 01, 2013 8:28 pm
It may be possible to use it, best bet would be to do a bunch of measuring. I was going to put one in my 92 I had, but I came across an actual aftermarket rear bench seat that was made for 1st gens...
Postby hager » Wed May 01, 2013 8:36 pm
No way ! Where did you get something like that I'd like to see a few pictures if i could
hager
Postby CumminsPower59 » Wed May 01, 2013 8:55 pm
This is the only picture I have of it...
Return to Body
