oil cooler Q's
Re: oil cooler Q's
Postby 1992gen1_fan » Mon May 06, 2013 6:41 pm
I rented a rad pressure tester. If I was to pressurize the coolant system and remove the oil filter, would oil or coolant come out of the filter housing if there was a hole in the cooler?
1992gen1_fan
Re: oil cooler Q's
Postby 1992gen1_fan » Sat May 11, 2013 7:52 am
I pressurized the oil cooler and it does'nt leak. It must be the head gasket or something.
1992gen1_fan
Re: oil cooler Q's
Postby apexfd » Sat Jun 01, 2013 8:57 pm
Where is the best place to buy an oil cooler from? Anybody run external oil coolers?
apexfd
