by CumminsPower59 » Tue May 07, 2013 12:53 pm
More progress made today. Got the steering gear mounted and drag link adjusted, trans and transfer case full of lube, A/C compressor and hoses removed, front half of the exhaust on, cab frame mounts bolted on, cab painted and floor sealed. Hopefully...tomorrow I can get the cab on.
As for the rear driveshaft, I did some measuring, there is still a fair amount of travel left, I measured exactly 1 3/4" of "inward" movement left. Should be enough for now.
Collapsed...
Bolted to the transfer case...
CumminsPower59 on Tue Sep 09, 2014 10:06 am, edited 1 time in total.
