Camplate R&D
Postby cummins king » Fri Dec 21, 2007 4:29 pm
thanks mr ford for the info
93 4X4 auto
cummins king
Postby SChandler » Sat Dec 29, 2007 12:01 pm
ford69557ci,
If the vane pump dismantles itself at 75-80 psi, why not run it with 60-65 psi to the inlet? Is there a big change in cc's of fuel delivered? I understand wanting to get every last bit out of the pump (and say thank you sir for the r & d you are doing for all of us), but it seems like you aren't gaining anything but unreliability. How is the 14mm head holding up? Are you planning on running the a1000 to the inlet and using the Pro Series pump to supply case pressure when you finally get your pump installed? Sorry bout all the questions but this and the crazy fuel system thread have got all sorts of ideas running through my head :evil: :D . Good luck.
SChandler
Postby cummins king » Sat Dec 29, 2007 12:37 pm
he mr ford
what did you port in the pump everyhting or you sertine things thanks
93 4X4 auto
cummins king
Postby ford69557ci » Sat Dec 29, 2007 3:28 pm
yes the vane pump comes apart at 75 or 80 and yes there is a slight difference in cc of fuel at lower pressure. i have it set at 68-70 now and have no problems other than keeping the shaft seal in. the 14mm h-r is doing fine i think the only reason anyone had any trouble with them was due to not havin enough fuel supply. i am just going to run the pro series pump only because with my large modified fuel inlet and all of the internal flow improvement it seems to be doing fine with the single feed. keep in mind though that the pump has only made it to 2500rpm due to the seal failure issues so at 5000rpm it may need the dual feed to keep up and that is somethin iwill figure out when i get the seal problem solved. as for whats ported in the pump??? everywhere that a drop of fuel can go has been worked on which included alot of extrude honing and that wasnt cheap.
ford69557ci
Postby cummins king » Sun Dec 30, 2007 11:09 am
ya a hunderd bucks at a time ah
whats the dallor value of ding somthing like that
93 4X4 auto
cummins king
Postby ford69557ci » Sun Dec 30, 2007 11:18 am
well i think i have around 500 in the thing since i had it done all at once. did it help with flow?? i would like to think it did but i really didnt have a baseline. i was going to start testing the pump in each stage but decided that would be a pita so i just build the thing once i had all of the parts and all of the machine work done but now i have to tear it down and do some machine work on this seal.
ford69557ci
Postby SChandler » Tue Jan 01, 2008 8:16 pm
That's awesome, thanks for all the info.
SChandler
Postby cummins king » Mon Jan 14, 2008 9:55 pm
hey ford any luck on the 4.5 mm cam plate, i want one so let me know, any luck on the seal
93 4X4 auto
cummins king
Postby ford69557ci » Tue Jan 15, 2008 4:38 pm
Yeah i got the plate have not had time to try anything out but the seal issue is still bein worked on i need to hurry and get this thing done cuz i have everything to put this beast together besides my 3rd set of test injectors
ford69557ci
Postby cummins king » Tue Jan 15, 2008 4:41 pm
can you pm me on the cam i got a pump that i need one for thanks
93 4X4 auto
cummins king
Postby ford69557ci » Tue Jan 15, 2008 8:21 pm
for the moment its a one off thing i hate to say its gonna be good if its worthless and you spend a bunch of money for no reason
ford69557ci
Postby cummins king » Tue Jan 15, 2008 8:46 pm
there cant be any harm in tryin, i was thinking your going to have to change the timing because the roles have to go farther to get over the hump there is a difrence in distance it is going to travel, did you check if theres enough room for the extra .5 of a mm,
93 4X4 auto
cummins king
Postby ford69557ci » Wed Jan 16, 2008 4:06 pm
nope thats next on the list when i start messin with this again im delayed cuz i had to buy two new engines for my boat so cash flow has slowed the r&d project
ford69557ci
Postby cummins king » Wed Jan 16, 2008 5:58 pm
well were did you get the cams from, send me the number, its probaly easyer to get it from you guy them me having to get sombody to make a new one, and if the your guy sees a demand he might lower the price abit
93 4X4 auto
cummins king
Postby ford69557ci » Wed Jan 16, 2008 7:32 pm
it is www. rocke-tech.com they dont list them on thier site but email or call them and they will help ya out
ford69557ci
Users browsing this forum: No registered users and 69 guests
