non-IC'd new radiator?
Postby Douglas » Fri May 10, 2013 5:07 pm
hey-Hey!!!,
Where can I find a reasonable source for a non-ic'd radiator for my 1990? I have seen the links a while back but have not been able to find it with a few searches. help please, I need a replacement for Lurch.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: non-IC'd new radiator?
Postby cmann250 » Fri May 10, 2013 5:16 pm
Did you spring a leak or it all plugged up?
I found this: http://www.partsgeek.com/catalog/1990/d ... iator.html BUT.....
The later style radiator is a cross flow model and if I ever need a replacement, that's where I'd go. I know they need a different water neck/thermostat housing and likely more.
Postby apexfd » Sat Jun 01, 2013 8:58 pm
Wow, good find. I put a hole in my radiator by accident and I have to braze it closed because a new radiator was going to be 400+$ locally..
apexfd
