So I've noticed on the '93 W350 that the bottom of the column gets a touch warm while normal operating, but when i run the Heat or A/C on the top 2 speeds, the column get really warm, enough you can't hold your hand on it for long. Is this a failing ignition switch, or do i need to do the heater switch relay i read about on DTR?
I'd like to use the A/C on full blast, but fear burning something up.
Thanks in Advance
