KTA wrote:Flow wise those injectors should be capable of easily running in the 700-800hp range, but I think they are awefully big tips for a VE. I at one time I had a set of 5x.025 for a pulling tuck application and they ran like crap and made terrible power for me. The VE isn't capable of generating as much pressure as a p7100 and subsequently the atommization suffers. I am anxious to here how these work out with your combo. I am glad to see someone else pushing past what POD's can provide.
KTA wrote:Prime example of what I always preach. DECIDE WHAT YOUR END POWER GOALS ARE THEN BUILD TO IT!!! Do not continuously upgrade or you are just pissing money away. Save your money till you can build what it takes to satisfy you and then do it, you will be way better off financially. Once you build it then in 6months you cant decide you want more, or else it just starts all over again and basically everything you had was a waste or a compromise. Modifying is a slippery slope with no $$$ end unless you can excercise self control.
