turbo question
turbo question
Postby gobcumminstruck » Wed Sep 04, 2013 9:22 am
what is the differets between an holset h1c and wh1c turbo? and well the inlet side from h1c fit on an wh1c? i find were it an wh1c needs rebuilt, the wh1c has exhuast housin and wastegate comes with it. i also find were theres the middle been rebuilt i may get it put i need inlet side thats why i was wondering
gobcumminstruck
Re: turbo question
Postby skilletky » Wed Sep 04, 2013 9:57 am
the w in wh1c means it is wastegated
skilletky
Re: turbo question
Postby RCCUMMINS89 » Wed Sep 04, 2013 10:42 am
HOWEVER......there are two diff. h1c turbos.
The Non I/c trucks have a smaller h1c on the compressor side.
Re: turbo question
Postby AHineman » Wed Sep 04, 2013 11:18 am
The baby h1c. :lol:
50mm compressor.
Re: turbo question
Postby ellis93 » Wed Sep 04, 2013 11:53 am
A true wh1c has the same inducer as a hx35,which is 2mm bigger than a h1c at 56mm vs 54mm.
I've got one tore apart in a box :)
Re: turbo question
Postby gobcumminstruck » Wed Sep 04, 2013 2:54 pm
so i take that as no. and how u measure the housing to know what it is??
gobcumminstruck
Re: turbo question
Postby ellis93 » Wed Sep 04, 2013 3:05 pm
I measured the ends of the turbine blades to find out what it was. I had the same thing told to me,that the wh1c was the same only to find out it was the same as the hx35. I don't know about the baby h1c but the turbine shaft interchanges with the wh1c,h1c,hx35,hx40(older) turbos,least thru all of my digging thats what I've came to understand. I bought all my rebuild stuff from gds when I was building my hybrid and even the guy there said the same.
I can dig up some old pics of how I did it if it'll help you out
Re: turbo question
Postby RCCUMMINS89 » Wed Sep 04, 2013 3:16 pm
The turbine housings are interchangeable......the compressor side is what is different.
Re: turbo question
Postby gobcumminstruck » Wed Sep 04, 2013 5:20 pm
to ellis93 yes thst b great and help full if u can. and to rccummins89 ok. ya thanks
gobcumminstruck
Re: turbo question
Postby ellis93 » Thu Sep 05, 2013 3:54 pm
